WorldExclusive
- Apr 26, 2009
You 7970 guys keep your eye out for those new drivers. I've got a couple of these incoming.
lol
I don't care what motive or competition nvidia has.The card is very costly compared to the last 580/680 cards. The fact that there is an EXTREMELY expensive Titan is causing people to think this card is a "deal" at $650. Its exactly the price conditioning nvidia wanted.
This is the kind of performance jump we all expected to come with from a 680 to a 780. If there was no Titan, would this be so much of a "deal" at $650? Hell, this is priced far enough away from the 680 that they dont even have to lower the price on that, and so on down the line. Its like the low/mid/high end cards have all jumped up a price level. Its bad for everyone except nvidias pockets.
So, from your apples-to-apples data, on average the 780 is 5 FPS faster than a 7970 for an additional $250 over what you can buy a 7970 non-ghz edition for.
What I'd love to know is how that value proposition changes when you overclock both of those cards to the max!
Check out the Tomb Raider benches. Good old green tinged [H]
Read from top to bottom and if you don't see whats going on, I have a Titan to sell ya![]()
Agreed.
With the same settings, the 780 is faster than the 7970 by about 5 FPS on average.
You really think that's the case?
continued...
Overclocking
To overclock the GeForce GTX 780 we used a beta version of Precision X provided by NVIDIA.
I am confused, if someone goes titan why... just get a 690 for $1,000
I remember the good old days when people claimed the opposite... and by good old days I mean the 5870 reviews
Peoples ability to see bias where none exists never ceases to amaze me.
Yep. Look at the Apples-to-apples Tomb Raider:
"In this apples-to-apples graph we are comparing with TressFX enabled at 2560x1600 on all video cards. The GeForce GTX 780 is 22% faster than the GeForce GTX 680. The GTX TITAN is about 11% faster than the GTX 780."
What they DIDN'T say was "GTX 780 is same performance as the 7970 Ghz!"
It will be funny if these new drivers release and 7970's all of a sudden provide an equal or better experience than 780's. Makes buying a 7970 in January 2012 for $100 cheaper than a 780 look like a pretty good move!
AMD bests NV without even releasing new hardware, now THAT would be worth a LOL!
They didn't mention the percentage difference between the 780 and 7970 in ANY of the Apples-to-apples. The only time they mentioned the 7970 in that section was for Metro. Beyond that, the Apples-to-Apples section for TR does not tell the whole story. If you look up the small differences between them allow the 780 to run at higher settings. Even at a lower resolution the 780 is able to push settings higher.
Current Specs : 3770k & GTX 690
I'm currently on the mini-ITX platform and hoping to upgrade to mATX SLI config.
What will be the best upgrade path ? Another 690 or something else?
Perhaps too cautious, but getting only %50 out of the second card always bothered me.
Another quick note... I asked Kyle about monitors, and he suggested I wait for a bit longer, like maybe around Halloween or such... He was very vague, so I am being vague, but yeah, I'm waiting.
Well, there are two caveats with that driver.
1. AMD says you have a choice between performance and smoothness. You can set the driver to ignore frametimes or reduce frametime latency at the cost of performance.
2. The driver is still a software solution vs Nvidia hardware solution which is still superior and not driver dependent. AMD will have to wait until the 8000 series to move the fix to hardware, but I'm skeptical of that because they just started working on the fix a few months ago.
No performance gain is coming with the new drivers. If anything, you'll see reduced performance because of reviewers/users choosing smoothness to evaluate AMD cards, prompting another price cut and ridiculous game bundle i.e. BF4.
1. That's not how the driver works, it simply fixes runt frames. There are no longer any significant amount of runt frames, if you want it performance the solution would be to use the old driver
2. Software isn't a "worse" solution, it performs the same, it just is more work for the GPU, possibly hampering performance. But if it works and still is faster, then it doesn't matter if it is hardware or software.
The new drivers have some performance gains, they don't trade FPS for smoothness, they just output a more consistent FPS.
AMD is still planning on releasing this driver in a beta form in the summer but I wouldn't be surprised to see the schedule moved up a bit with some pressure with the Radeon HD 7990 release and better than expected results thus far. AMD continues to promise the ability to enable and disable this feature in the control panel as well as to enable it on a per-game basis, something that NVIDIA hasn't done yet. There are debates on whether or not there are actually input latency benefits to AMD's current method and we are still finding a way to test that at PC Perspective.
That's interesting.
But it would be really hard to beat the Qnix QX2710 currently selling for about $310 shipped.
2560x1440 Samsung PLS
and it overclocks to 96 Hz and some make it to 120 Hz.
As for maintaining or gaining performance with this driver. GPU performance is rated on FPS and AMD are removing runt frames to smooth the framerate, how does that maintain or gaining performance?
The original debate was CF stuttering and suspect FPS numbers that were higher than actually seen on the monitor.
Which means the GPU is slower than perceived. Continue reading the article to see what I'm saying here. FRAPS FPS vs Observed FPS.
The prototype driver I've been using doesn't have that feature as far as I know.
Think about it. If you meter the FPS, the runt frames simply become acceptable frames. The problem isn't "the GPU is getting more FPS for less work", but rather "the GPU is displaying less results for the work it did". If you meter the frames, it can still draw the same amount of FPS (give or take maybe 5%) while removing runts. Any performance losses in the driver are because it's currently based off of an old driver revision, not the latest Cat beta.
Ok, before I continue to speak on this and venture of into ignorance, I'll hold final judgement until it's official released. It seems like you had hands on experience with this.
I hope you're correct because that would make AMD an option for me in the future. The stuttering was main thing and the frequent/late driver releases was the second thing.
On page 7 of the GTX 780 review (Overclocking):
Perhaps you meant to say EVGA? (Or Rivatuner in that matter...) Because we know that NVIDIA doesn't make anything like that.
NVIDIA provides the beta versions of the program, they work with EVGA to create the new technologies in it for the gpu launches, it is the program they give press to overclock with on new gpu launches now. So yes, I go this directly from nvidia.
Places like Anandtech, PCPer, TechCrunch and Hardware Canucks all realize that FPS measurements are misleading for showing the true performance of a system.. especially since FPS takes into effect runt frames which give the FPS rating a fake boost.
Frame Time is what those sites have shifted to and only include FPS ratings for people who don't know that Frame Time is the new standard and need to be eased into it, or simply as a secondary metric.
I'm very dissapointed to find you did nothing with Frame Time.
Lol.
Nice card but I'd rather spend the money on two 7950s.
