Nenu
[H]ardened
- Apr 28, 2007
HDR can also be mapped onto 8 bits.It can't be 8-bits for HDR. The various HDR formats require more than 8-bits.
My real takeaway from that german review is that the reference cooler actually isn't a huge problem. You can sustain 2.1Ghz on the reference card with the fan at 55%. But that's your cap-- you can't get past 2.1Ghz because the reference card is power-constrained. The real point of AIB cards this generation might be that they come with another power connector.
The evga OCX power target slider brings it very close to the actual power provided from the pci-e slot plus the 8-pin power connector. The juice has got to come from somewhere!Oh just takes a little bit of solder on the power resistor and that problem goes away... or I am sure BIOs mods will come out.
They are absolutely allowed to yes, I suspect we will see some dual 8pin designs.
It can actually perform as a passive heatsink, I noticed heat was spread across it quite evenly, and very hot to the touch.
Well yeah, that's why it sucks for everybody.Now I pay $100 for this same privilege, with nothing to show for it and it immediately depreciates to the actual $600 MSRP that a normal card is, which is probably even faster.
Well, there are a couple points to be made here.Wait, so you get a massive overclock with the fan only running near half speed? Why are people complaining about great performance without some sort of penalty, such as noise?
Whatever causes an overclocking limit will be complained aboutWait, so you get a massive overclock with the fan only running near half speed? Why are people complaining about great performance without some sort of penalty, such as noise?
Your thoughts are again noted.But whereas he seems to see the glass as half-empty, I see it as half-full.
I guess you are asking how slow the fan will go? Considering it is nearly silent at 55%, I don't think sound should be an issue for the FE card at all.Question: what is the lowest rpm the card will go? I'm talking about idle, of course, because after finally upgrading my psu to a EVGA G2 it seems the noisiest componente @ idle is, by far, the gpu, because it won't go lower than 1.4k rpm and I don't want to edit the bios and void the warranty.
Yup, that is what I was asking. 55% is 2.200 rpm, I think? I even hear my 290X Tri-X @ 1.400 rpm so... I need something that goes even lower![]()
Why didn't you guys tear it apart and cool it down with LN2/water? I'm sure lots of people on the forums would have supplied you the goods. I came to this site after Linus failed to OC the card and let everyone know what [H] has provided with less noise.
Also, I wonder how long it will take for custom PCB makers or amateur engineers to get some extra power to the GPU. Dual 8 pin in the 1080tiP.
When the custom designs retail for $6-700 what do we do with all the 980ti's in the Buy/Sell thread? I feel like the 1080 is underwhelming considering the investment nVidia and its partners put forth to create it. Would it have been too much for TeamGreen to wait and add dual power connectors and release it later? Its not like AMD will have anything. I feel like the 1080/1070 will help fill the pockets of all the people hurting from the long term investment, and the real 1080ti will be what they developed from the start but did not release -- only scale back down because jumping too far ahead hurts their profit.
I need to sleep because my comments mean nothing.
Wow, so 980tis are only fetching between 390-450 on ebay, used. I have an AIO on mine so I might get a bit more, maybe not. I don't think it's worth it for me to go back to reference cooling on a new card when I'm running a whisper quiet 980ti.
I think I'll toss money towards an ultrawide curved/gsync monitor at this point. Unless the 1080 sli benchmarks are really impressive. But I'd hate to go back to SLI.
Hmm I wonder what the standard is. My sg13 was pretty tight with the MSI 980ti gaming 6g, like almost to the edge (extending into the front plastic panel past the metal frame). That had a stated length of 10.59"
I have a very quick question on the noise front: does the card still idle with three monitors attached? What about three 4K monitors? One of the things that really annoys me with earlier Nvidia cards is the card switching into high gear, with resultant fan noise.
all they said, it was already asked several times, is that is very quite. but they only let it run stock and the fan maxed at 55%. when the article on OCing comes out it will probably have more info and be in there.One thing missing int he review (unless I mistakenly overlooked it) is the sound of the card. One of the things I always try to find in a video card is how loud the card gets under load and things, generally trying to find one that's quiet since I tend to use my pc for lots of streaming netflix and things, having a noisy pc is something I try to avoid at all cost and it's just a little pet peeve of mine when playing dialogue heavy games having a loud roaring fan drives me nuts.
How loud does this card get under load and things?
I think that those who are tossing out their GTX 980 Ti / GTX TITAN X cards and selling them for cheap on eBay for cheap are going to feel really bad when the GTX 1080 Ti and GTX Titan (?) will be released later on, possibly Q4 2016 or in 2017. Especially if you have a GTX 980 Ti SLI / GTX TITAN X SLI setup, then I would wait until next year to upgrade. It is more than likely that 4K display @ 120Hz will be available by then, possibly with HDR support.
By the time those new displays will be available, the GTX 1080 will be obsoleted / surpassed by video cards with the big Pascal GPUs: the GTX 1080 Ti most likely 16GB HBM2 and GTX TITAN (something) most likely with 32GB HMB2. This is pure speculation of course, as NVIDIA usually likes high profit margins, so I would say that a more plausible scenario will be to use GDDR5X in the 1080 Ti and new TITAN (?) cards. If they will go with a 384 bit bus for the upcoming high end cards, then I think we'll get a GTX 1080 Ti with 12GB GDDR5X and a TITAN (?) with 24GB GDDR5. Again, all of this is pure speculation on my part.
The review was really well written and up to 30% speed improvement over the GTX 980 Ti is nothing to sneeze at. I will however not trow out my EVGA GTX 980 Ti Classified SLI cards just yet.
