Dayaks
- Feb 22, 2012
Did I miss the sound profile information?
Here's a review with noise readings. It's quiet.
NVIDIA GeForce GTX 1080 8 GB Review
Hard for us to make comparisons when we do not have the hardware in hand. Hell you can read in this thread alone, we made one opinion about Async Compute for AotS and someone gets their panties in a wad because we have no proof. If I had proof, it would not be an opinion, it would be a fact.Oh, most definitely! We were comparing the value of Nvidia's Founders Edition to an AIB's version of a reference 1080.
Damn near silent, just like the 980Ti ref card.Did I miss the sound profile information?
Also it still seems the Async Compute is disabled within the DX12 render path for NVIDIA; Ielda tested using both the newer driver (meant to handle how to deal with the Async Compute issue and so bypassed by driver rather than application) and older one with the latest version of AoTS on Steam.No, it is a theory and opinion of me personally as I stated. I think it is an application issue. Same reason why Tomb Raider is also slower on every GPU in DX12, just not a good implementation of DX12 itself.
Not sure who that is you are referring to, but reference cards have NEVER had better cooling solutions than high end AIB cards.....pretty much ever. I think you might be able to argue that ref cards from recent years have better circuitry, but maybe not capable of supplying more power cleanly than AIB cards. Ref cards are built like little tanks to run forever at stock speeds. Once you start taking those outside of that profile, all bets are off. Those cards are simply not designed for that.Hypergreatthing was talking about Nvidia toting the Founders Edition as having a better cooler and circuitry, not the aftermarket boards. I think there was a small misunderstanding.
So that they could sell you a 1080Ti next yearI still do not get why they kept it at 64 ROPs like the 980 though, when it has more SM/Cuda Cores/Textures.
Surely it would had contributed to the performance, assuming bandwidth is fine (would be up to 1440p).
Cheers
Maybe it's just me, but I would gladly pay $80 - $100 to have:
If instead of setting it's own fan speed, it was told to run the fan higher, say 60, 75, 100%, what effect would that have on the auto-boost clocks?
30% improvement seems low for such a node large shrink, however my question is :
Are AIBs allowed to add circuitry and VRMs for a second power input? It seems to me the card is just throttling because of the power limit imposed on the card, similar to the Nano. Any word on this?
I still do not get why they kept it at 64 ROPs like the 980 though, when it has more SM/Cuda Cores/Textures <----- Doh actually same number of cluster as 980.
Cheers
Edit:
NVM, probably comes back to the cluster of 4, same as 980 and where the 980ti had 6.
Why do people care so much about a backplate? It doesn't do anything
Makes you wonder if AIBs might capitalize on that for some better passive cooling. I think these cards have huge upsideIt can actually perform as a passive heatsink, I noticed heat was spread across it quite evenly, and very hot to the touch.
I noticed VRAM usage of 7 GB in one of the tests. As such, all the other cards in that test would have been VRAM-limited. It would have been interesting and useful to see how the 8 GB 1080 compared against the 12 GB Titan X and the 8 GB 390X.
From reviews measuring fan speeds versus performance it's very clear the reference 1080 is constrained by temperature, not power. With much better AIB cooling that may change. Or it may not-- we don't know yet, maybe GP104 tops out around 2.1Ghz regardless.They are absolutely allowed to yes, I suspect we will see some dual 8pin designs.
No offense, I do not know who that is, and quite frankly do not care. I would suggest you ask him questions about his opinions. If you have questions about our content on our forums, I am fully open to that discussion.Hypergreatthing was talking about how he wants...
A bit borderline with 4k. I was excited about this - still great, but not quite there yet. Looks like my 980 will be hanging around until 1080ti.
Very hot? That makes it even more difficult for those of us with mini-ITX cases.
Quoting myself here, but a german site reviewed the FE card with aftermarket cooling, the Accelero Xtreme IV. I can't speak German, but videocardz's conclusion from their video was that with great aftermarket cooling the 1080 is indeed constrained by power!From reviews measuring fan speeds versus performance it's very clear the reference 1080 is constrained by temperature, not power. With much better AIB cooling that may change. Or it may not-- we don't know yet, maybe GP104 tops out around 2.1Ghz regardless.
So for those who have 980 Tis, is this worth considering an upgrade?
Seems a bit toasty for a cooler they're charging an additional $100 for.
I skipped Kepler and Maxwell so let's see if I can hold out for Volta.![]()
Heh, exactly what I said. Glad great minds think alike. I'm looking forward to that article.Time was limited. I like to get all the default data done in the initial launch review to understand where the card is at and what the baseline is. Then we can construct a review solely for overclocking, take that data, and see the improvement. First you have to see where you are starting from, then you can compare that with where you are going. We now have a solid base of information to compare to overclocking and I can focus solely on that for an article.
Also, I was under the impression that a backplate adds to the rigidity of the card; less potential for bending. I personally prefer a card with a backplate over one without for aesthetics (hides the electronics). The passive cooling it provides as well is a bonus.It can actually perform as a passive heatsink, I noticed heat was spread across it quite evenly, and very hot to the touch.
NVIDIA GeForce GTX 1080 tested with aftermarket cooler | VideoCardz.com
So when AIB cards with additional power connectors come along with cherry-picked GPUs and high-end air coolers, we can reasonably expect to get well past 2.1Ghz.
Yes, also good links. We know there's a spot for a second power connector on the 1080 reference cards. Since they're power-constrained, that's yet another reason not to buy the reference. Hold out for a few more weeks, friends! We can do it!TPU so far has spent a fair bit of time looking at the behaviour and performance window of the Boost 3/temperature/clocking.
Some of the tools inside of Boost 3 that are going to need to be used are still in Alpha from the AIBs. NV has seemingly finished the structure, just waiting for AIBs to put their UI on those.I think Kyle/HardOCP is right to take the time on this one, especially as the right tools to do this for this new approach in Boost3 are still sort of in beta.
I'm still considering the 1070's SLI'd - curious how the new sli bridge will play into this.
My real takeaway from that german review is that the reference cooler actually isn't a huge problem. You can sustain 2.1Ghz on the reference card with the fan at 55%. But that's your cap-- you can't get past 2.1Ghz because the reference card is power-constrained. The real point of AIB cards this generation might be that they come with another power connector.Unfortunate that they are charging a premium for essentially nothing, that only punishes SFF builders. Great marketing spin though, that they charge $100 on something that performs worse than an EVGA AIO cooler which is also in the $100 ballpark.
Also they mentioned keeping reference cards in the supply chain for charging an extra $100. Except no one has trouble finding a reference 980 Ti a year after release. A complete manufactured "problem".
If you overclock a lot and use the card a lot it can help the card last.Why do people care so much about a backplate? It doesn't do anything
