No, 379 (450) is not an affordable price for everyone. I'm sure NVidia would love everyone to accept that as affordable. If there is one GPU that I hope will do that it would be 1060 with better/similar performance than 970/980 for less than 200/250.
Because you will need a big brick shithouse power supply to keep those cards fed ($10 says 2 of those will suck at down at least 500 - 600 watts of power alone) and you will have to install another A/C to keep up with the heat that will be pouring out of your case. If you already have a good case and a beefy power supply then ok, you might be on to something (well, excluding the PITA that CxFire / SLI can be for other reasons) but if you don't, you would be just better off buying a top end single card solution.
Didn't Nvidia just have to pay people over the GTX970 3.5GB issue? If this is true, it'd be the same thing.Not to stir up shit, but...
Has anyone seen the 1070 use more than 7GB of memory? It's my understanding the RotTR, specifically, easily saturates a card's VRAM with Very High textures, using all of the 1080's 8GB. But I have yet to see any numbers where the 1070 is using more than 7168 MB (87.5% of 8GB ).
A thread up on the NVIDIA Dev Talk forum is showing the GTX 1070 only averaging around 190-200 GB/s in the first 5GB.
https://devtalk.nvidia.com/default/...ormance/gtx-1070-cuda-mem-performance-thread/
Thoughts?
