NVIDIA GeForce Game Ready Driver 417.71 WHQL Has Been Released
Discussion in 'HardForum Tech News' started by cageymaru, Jan 15, 2019.
  1. Derangel
    Derangel [H]ard as it Gets
    17,535
    Jan 31, 2008
    Slightly off topic but how do you like that monitor? It’s been one I’ve kind of had an eye on for a bit and now that you say it works perfectly with Nvidia’s implementation I am very interested in it.
  2. dvsman
    dvsman 2[H]4U
    2,638
    Dec 2, 2009
    Cool, my setup was acting wonking with 3 different monitors and 3 different refresh rates. Let's see if this fixes the issues - can't wait to get home to try it.
  3. Parja
    Parja [H]ardForum Junkie
    11,594
    Oct 4, 2002
    I ordered one through Walmart. Looks like it'll arrive in about a week. Worst case, I can just return it to my local store if I don't like it, so basically no risk.
  4. bizzmeister
    bizzmeister [H]ard|Gawd
    1,491
    Apr 26, 2010
    Am I the only guy running a 1080Ti on a g-sync monitor but doesn’t give a fuck nor use it?
    Uncap my FPS and boom, no fucks given about g-sync.
  5. jpcahn1
    jpcahn1 [H]Lite
    66
    Apr 17, 2014
    If you have a Samsung CHG 70 I can report that it is working. The onscreen display of the monitor itself only shows the main refresh rate such as 144 hz. It does not fluctuate up and down even when using an AMD card. There is an option on the top of the Nvidia control panel for Display, Gsync Compatible indicator. It will show when Gsync is working. On Shadow of the Tomb Raider it would work in Fullscreen but not Exclusive Fullscreen. I am not experiencing any flickering or blurring issues whatsoever. Looks like I can hold onto the old 1080ti a while longer now.
    Maddness likes this.
  6. Parja
    11,594
    Oct 4, 2002
    You must love tearing. But seriously, you've never even turned it on? Why not? G-Sync doesn't even add latency.
  7. bizzmeister
    1,491
    Apr 26, 2010
    Never turned it on. Never felt the need to try it, never bugged me.
    I have the 27” Dell 1440p 144hz 1ms gaming monitor. Forgot the model # sdg27r or some crap.
  8. NWRMidnight
    NWRMidnight Limp Gawd
    274
    Oct 23, 2010
    So you spent an extra $100+ on a monitor for a feature you never turned on or used... That just doesn't make good sense.. but each to there own I guess.
    Armenius and bizzmeister like this.
  9. bizzmeister
    1,491
    Apr 26, 2010
    Pretty much lol. I got a great deal on it. Wasn’t really looking for Gsync at all. Just wanted a good 27” 1440p 144hz gaming monitor bro.
    Looks like I’ll have to try it out tonight when I get home.
  10. wizzi01
    wizzi01 [H]ard|Gawd
    2,021
    Apr 25, 2008
    Did anyone else have the GeForce experience greyed out so you had to install it? This is the first time this has happened.
  11. misterbobby
    misterbobby 2[H]4U
    3,709
    Mar 18, 2014
    Sounds like you did not pay careful attention to the beginning of the installation. You are first given a driver or driver with geforce experience option. The geforce experience is the default so you must have simply clicked on "agree and continue" without noticing it.
  12. RogueTrip
    RogueTrip 2[H]4U
    2,789
    Feb 22, 2003
    Looks like joker productions put something up. Did not watch it yet.
    Krenum likes this.
  13. nightanole
    nightanole [H]ard|Gawd
    2,016
    Feb 16, 2003
    Viewsonic VX 3258 works.
    And boy howdy you better have frame rate limiting on. I loaded up shadow of war and hit 800-900fps till it hit the menu.
    Also it was not hard at all. I just had to goto "setup gsync" On nvidia control panel, and just had to select windowed/full screen, and "enable setting for this monitor". Thats it, it wasnt six steps.
    Armenius likes this.
  14. jolli
    jolli Gawd
    753
    Dec 17, 2010
    You sure it’s not turning on by default? I have that Dell monitor and it likes to automatically enable itself whenever I install the Nvidia drivers.
  15. Krenum
    Krenum [H]ardForum Junkie
    15,407
    Apr 29, 2005
    How so? Alt+R "click Freesync on". :confused:
  16. nightanole
    2,016
    Feb 16, 2003
    That flies in the face of everything i have read.
    Ok so he has freesync enabled
    He has vsync enabled
    He says if he goes below the freesync range of his monitor, he gets tearing
    He says he enables vsync to cap frames.
    Now based on what i have read (im no expert), you do not enable vsync when you have a gsync/freesync enabled. It defeats the purpose.
    The other thing i thought was odd in his video, is he says he sees tearing when below freesync range. Now i have 2 problems with that. First is he has vsync on, so he should NEVER have tearing. Second is I assumed nvidia enabled LFC when running a monitor that has a VRR ratio of at least 2.4x, just like AMD, this would mean again zero chance of tearing. VRR via gpu would kick in and start duplicating frames based on an algorithm.
    So if we have any "experts" out there:
    Should we run with vsync on or off?
    Does nvidia enable "software/GPU" LFC when going below freesync range?
    Oopy Doopy3 hours ago (edited)
    Edit: Did more research, you should enable v-sync globally in the nvidia drivers. Nvidia does indeed do something funky. Optimally, you enable v-sync in the nvidia drivers and then set a framerate cap (optimally with an in-game limiter) 2 frames below your refresh rate to minimize input lag. You should not use v-sync. If you want your fps capped, you could: A: Use Nvidia Inspector to set a global cap or a per application cap B: Use Adaptive v-sync. This caps your framerate at your refresh rate and syncs to the display, and drops v-sync when you dip below the refresh rate. (I suspect this is what Joker intended to do but misunderstood/forgot) C: Use rivatuner to cap the fps (this is the lowest input lag option, but requires additional software to run with all your games) Maybe nvidia does something with the driver to change the way v-sync works when g-sync is running, but if not then turning on v-sync completely negates running g-sync/freesync. You'll get that v-sync stutter at variable framerates because....well, v-sync is running. Having run some games with v-sync on and g-sync on, the stutter is real and honestly it seemed worse than v-sync w/o g-sync. I haven't used driver level v-sync though. I imagine your experience will vary from system to system and monitor to monitor, but with my setup, v-sync + g-sync is awful, g-sync + framerate cap is A+. https://www.blurbusters.com/gsync/gsync101-input-lag-tests-and-settings/6/
  17. nightanole
    2,016
    Feb 16, 2003
    You could say i had a handshake issue like the early days of HDMI and HD boxes. And i was running over HDMI. My monitor would allow freesync to be ticked unless it saw a freesync card, and just ticking freesync on AMD panel didnt seem to cut it on the first attempt.
  18. IdiotInCharge
    IdiotInCharge [H]ardForum Junkie
    10,412
    Jun 13, 2003
    Off.
    Depends on how asstastic the Freesync implementation is.
    Krenum likes this.
  19. Krenum
    15,407
    Apr 29, 2005
    I was always under the impression that you turn Vsync off if you're using adaptive sync (Freesync / Gsync). When he turned on Vsync that kind of confused me because if you enable adaptive sync, the framerate doesn't exceed the Hz limit, which is tied to the frame rate.
  20. bizzmeister
    1,491
    Apr 26, 2010
    Positive. Because I’d go in there and make sure it’s off.
    And also the fact that I’m seeing above 200fps in the games I play would also confirm.
  21. jolli
    jolli Gawd
    753
    Dec 17, 2010
    Maybe it changed, but I thought G-sync just shut off once you exceeded 144hz with that monitor. It doesn’t limit your frame rate to the max supported monitor refresh rate by itself.
    Which is why they suggest using a frame limiter or Vsync (through the control panel not the game) to avoid tearing. See: https://www.blurbusters.com/gsync/gsync101-input-lag-tests-and-settings/14/
    Armenius and Maddness like this.
  22. FrgMstr
    FrgMstr Just Plain Mean Staff Member
    48,213
    May 18, 1997
    I have not a single FreeSync display in any of our offices currently.
  23. KazeoHin
    KazeoHin [H]ardness Supreme
    7,804
    Sep 7, 2011
    I think it's up to the [H] community to report as accurately and objectively on Nvidia's FreeSync support.
    Armenius, Maddness and IKV1476 like this.
  24. Sonicks
    Sonicks [H]ard|Gawd
    1,401
    Jul 24, 2005
    Installed the driver, opened up the Nvidia control panel, Windows 10 notification popped up saying my XG270HU monitor was detected as G-Sync supported, the option was enabled by default, so I then got to gaming.
    Honestly it seems to work so well I can't tell the difference. I'll have to play games that I recall having tearing issues with but so far I guess it's doing it's thing? I do feel better that this monitor is now being fully utilized.
    Cactusj likes this.
  25. wizzi01
    wizzi01 [H]ard|Gawd
    2,021
    Apr 25, 2008
    Sounds like you made a wild ass assumption. I always custom install and uncheck everything but the driver's.
  26. SSimmons05
    SSimmons05 Limp Gawd
    203
    Mar 11, 2007
    These drivers not only increased my average and lowest FPS ON my 2080, but gave me GSYNC on my Acer XG27 freesync monitor, popped up automatically right after drivers finished installing. And wow, just wow, I didn't realise what I was missing, especially in areas where before I had lag or tears from big fps drops in demanding scenes, it's like butter smooth now.
    Armenius, cageymaru and Maddness like this.
  27. misterbobby
    misterbobby 2[H]4U
    3,709
    Mar 18, 2014
    Yeah how dare I try to point out what you may have done wrong. And what you are saying now shows that you cant even pay attention here no better than when you were installing the drivers as AGAIN the part where you messed up was at the very beginning before you even get to the custom install option. :rolleyes:
    EDIT: This is where you are screwing up.
  28. Sonicks
    Sonicks [H]ard|Gawd
    1,401
    Jul 24, 2005
    misterbobby is correct.
    The very first thing the installer had you choose is "Driver and GeForce Experience" (default option) or "Driver only". It is only after you make a selection and hit "Agree and continue" that you get the Custom install option. The custom option will have all the check boxes for you to choose what to install but it will not allow you to deselect GeForce experience if you left the very first option during the installer at the default.
  29. JosiahBradley
    JosiahBradley [H]ard|Gawd
    1,724
    Mar 19, 2006
    Can confirm for the Asus MG279Q G-SYNC does *NOT* "JUST WORK". Frame rate is 90hz on desktop and locked at 29/30hz in full-screen apps.
    EDIT: Maybe all the monitors that "failed" were because nVidia's drivers suck at adaptive sync????? This "just worked" on AMD.
  30. wizzi01
    wizzi01 [H]ard|Gawd
    2,021
    Apr 25, 2008
    I fixed my issue by reverting back to the old driver's. Even tried to reinstall the garbage they put out today. Even clicked the first option back and forth multiple times to make sure. You know the install with GeForce or not option.
  31. misterbobby
    misterbobby 2[H]4U
    3,709
    Mar 18, 2014
    Maybe get someone to help you next time as these drivers install just fine without GFE if you click on what you are supposed to...
  32. Sonicks
    Sonicks [H]ard|Gawd
    1,401
    Jul 24, 2005
    On my XG270HU, I seem to be getting black-outs when non-fullscreen elements pop in or out of a game and when surfing the internet.
    Examples: The Windows 10 "Game Bar" is a window that pops up over full screen games and when this menu pops up, the screen blanks out for half a second, then when the game bar menu is dismissed the screen blanks out yet again. The same thing occurs when Windows 10 achievements pop up in the corner during a game. Another time this occurs is when watching YouTube just before and after switching the video to full screen.
    Doesn't seem to be affected by either of the two G-Sync options.
  33. Kor
    Kor 2[H]4U
    2,176
    Mar 31, 2010
    For G-sync to function correctly (frame time variance compensation) you need to enable vsync for the application, either in the game or from the driver. Anecdotally a lot of games vsync options don't play as nicely as the driver level vsync in my experience (especially Destiny 2's in game vsync, that thing causes all kinds of frame time issues), so I've taken to forcing it from the control panel for my games. G-sync will still remove the latency from the double/triple buffering bellow the monitors max refresh rate.
  34. Evil Scooter
    Evil Scooter [H]ard|Gawd
    1,912
    Sep 22, 2000
    Seems to be working on my HP Omens. No tearing with Pendulum demo... wonky in BF5. Seems to work better with Vsync and frame limiter on set to 60.
  35. Minutemaid
    Minutemaid n00b
    19
    Nov 5, 2011
    Happy to report my ASUS MG278Q G-SYNC Compatible monitor experience with G-Sync has been flawless so far.
    I have a 1070 so was able to run some games that dipped below 50fps to really see that it was working. (y)
  36. Shadowed
    Shadowed Limp Gawd
    496
    Mar 21, 2018
    I wonder when Gears of War 4 players can upgrade from 385.82 to prevent non stop crashing?
  37. NKD
    NKD [H]ardness Supreme
    7,530
    Aug 26, 2007
    Yea you are not suppose to turn vsync on from what I have read. Not sure how correct he is with that.
  38. NKD
    7,530
    Aug 26, 2007
    huh? I thought it was a general concession you have gsync and freesync so you don't have to deal with vsync lol. Never used vsync with my freesync monitor works flawless.
    Now Maybe it's a different story if you are using 60hz monitor. But Gsync is suppose to automatically cap fps at 144 or 145.
  39. Kor
    Kor 2[H]4U
    2,176
    Mar 31, 2010
    The cap still works, it's just the frame delivery time that gets out of whack.
    Edit: Just to add some actual data to what I'm saying - https://forums.blurbusters.com/viewtopic.php?f=5&t=3073
    Nvidia in general have done a terrible job with explaining how the various parts of G-Sync work however for the smoothest experienced running an NVCPL vsync while gsync is enabled should be your go to.
  40. Armenius
    Armenius I Drive Myself to the [H]ospital
    17,478
    Jan 28, 2014
    Read the BlurBusters article again. The best experience is V-Sync (driver) + G-SYNC + Framerate cap and turn V-Sync off in your games with the framerate cap one blanking period below max refresh rate (142 on a 144 Hz monitor, for example). If you want the lowest input lag, then you turn V-Sync off, if that average of 2ms more input lag at 60 Hz is really going to bother you (it's going to be less to non-existant at higher refresh rates).
    This goes back to when G-SYNC first came out and people were bitching about G-SYNC capping your framerate automatically, so NVIDIA made the cap optional with V-Sync. Without V-Sync enabled you can have unlimited FPS with G-SYNC, but of course G-SYNC doesn't operate outside of the max refresh rate.
    They fixed the crashing a long time ago with one of the first 400 series drivers.
    Read my reply to Krenum above. AMD never made this change to FreeSync.
    Parja, IdiotInCharge and djoye like this.
