Put the RX 480 4g in last night to replace my NVidia 760 2g and ran:
Display Driver Uninstaller Download version 17.0.6.8
http://www.guru3d.com/files-details/display-driver-uninstaller-download.html
It's glitchy ... I have to keep restarting in order to get things working but, one restart usually does it. When I put the 480 in the x16 slot it would never show up to be detected in the devices so, I ended up having to put it in the next slot which is x8 - is that ok or will that cause me any performance issues?
My current system:
GPU: RX 480 4g
CPU: AMD Phenom II X4 955
MB: MSI 790FX-GD70
RAM: 8g Mushkin 1600
PSU: Seasonic X-750w
HD: WD 500g
HD2: 3T SeaGate
EX.HD: WD Passport 1T
Case: Antec One Illusion w/4 fans
OS: Windows 10 Pro, 64-bit
Liteon 24x: iHAS324
Monitor: Asus VH222
Is there any way to test that x16 PCIe slot to see if it's even working properly? That could be the issue or, it could be the 480 or both. I had to have my 760 in that x8 slot too and forgot about the issue with that x16 PCIe slot.
