I use The Novell Client 4.91 sp2 and when I turn my computer on, I get the novel prompt.
It prompts me for a network user name and passcode, well there is also an entry in the advanced options for a local workstation name.
So you could log into the network under a specific network name and you could also log into the local workstation under a specific name.
Well my problem is, when I enter a network user name it also appears in the local workstation name entry box.
How can I un sync it so that when i put in a network user name it DOESN"T put that same name into the local workstation user
Thanks
Thanks
