Norwegian Military Using Oculus Rift To Drive Tanks
Ducman69
That's actually really smart. The viewport is always going to be a weak spot. Hopefully they have redundancy built in though.
Ducman69
And at some point too you might ask, why not have a mothership tank with pilots nearby, and remote control some tank drones! Imagine how much more durable you could make a tank if you didn't need a giant air cavity for a crew and crew life support functions under sealed conditions.
In fact, one pilot could operate multiple drones, setting some up to move and fire in unison, or leave two on sentry while you explore with just a single, then tell the sentry drones to fall back in formation.
Could be a real force multiplier.
jmmahon1224
With current technology, is the loader more efficient than a mechanical system? May be a major prohibition to moving to tank "drones".
D
Deleted member 126051
Guest
Yeah, but with Facebook live-blogging the tank's position...
"Hey. Why'd I just get a bunch of ads for funeral services and life insurance? FFFFUUUUUU"
*ARTILLERY STRIKE!*
BladeVenom
The T72 tank has an autoloader that does 8 rounds per minute. I think a good crewman is almost twice that fast.
viscountalpha
A crewman gets tired, the autoloader can malfunction or break.
Not sure which I'd rather have. Why not both?
Remon
Is Oculus paying them to advertise them or are they trying to be with the hip crowd? Cheap VR goggles are nothing new, yet it's only after all this hype started we are seeing stuff like this.
westrock2000
Because there is the possibility that that "one" pilot may not be who you want it to be.
Kymer
They're using it so tanks can see animals eat or drink? They plan to use tanks to monitor animal farts next?
drakken
The loaders job is so that the tank can fire even if something goes wrong. The rift actually makes sense in this case. It is less likely to take damage that several lcd screens would in the even the tank takes damages that does not kill it. It would allow the tank to have a closed system. Ie filters to prevent chem weapons from disabling it that a open port would not. Also Norway is cold this lets the tank be sealing up to save fuel on heating the tank. Last space is at a very premium inside any tank, the rift would save space. The only down side would be if it got hacked through the com system.
