morningreis
- Aug 10, 2005
Hmmm.... I don't know much about the politics and money behind these contracts, so I can't comment on this being a "jobs program" for Northrop-Grumman. However I was an F-15 tech for a number of years (primarily Es), and while Boeing was in charge of the overall airframe and system integration, many, if not all of the systems in that aircraft came from pretty much every major player in the game, including Northrop-Grumman, depending on configs. It's safe to assume that this is true for other airframes also, so I'd be hesitant to say that Northrop-Grumman would go broke just because they didn't have the contract for a major airframe, because they certainly have dealings in various places. But then again, I don't know their financials or any of the politics here.Because we're talking about taxpayer money here. In theory, the company with the most recent experience with stealth bombers should have an easier time developing a new stealth bomber. Easier time means that the project will be delivered on time and not over-budget as a result. That company is Northrup-Grumman on account of its B-2 stealth bomber.
Whereas Boeing hasn't really made a bomber for close to 40 to 50 years now let alone a stealth bomber. As such, they would have a had higher learning curve and therefore would have been more than likely over-budget and slip way way past the expected service date. Lockheed, on the other hand, considering how they screwed up the F-35 and LCS program, I wouldn't be willing to trust them at all.
There's also the fact that this bomber is really the last major combat aircraft program for the next 15 years minimum. More than likely 20. As such, whoever lost would need to have other major programs to keep them alive until then. Unfortunately, Northrop doesn't really have a major aircraft program compared to Lockheed (F-35, LCS, C-130J+, F-16) or Boeing (C-5, F/A-18E, F-15E, SLAM-ER missiles, etc). So this bomber program is basically a jobs program for Northrup.
A man less bomber fully loaded that can escape the most advance missile defense system would be one heck of a plane to hack and hijack. To fly a plane without pilots leaves it open for failures which a human can handle (like a fire, loose items in the plane or ones that break free etc.) I can see smaller unmanned bombers but not something as expensive as this.
Having a plane with pilots also introduces a host of problems of its own. You need to have an ejection seat, displays and controls for the pilot obviously, which is a lot of expense, weight, and a lot of extra maintenance. Often times with bomber aircraft, you need long range and long flight times, so you probably won't be supporting a single pilot. Then you need a bunch of life-support systems like systems to maintain cabin pressure, oxygen system. Standard stuff, but if you cut this out the potential for simplicity and savings is large.
Assuming you can maintain a proper link with an aircraft, there is no reason a pilot can't remotely deal with an engine fire. If your instruments tell you that you have an engine fire, then you can fire off the fire-suppression systems for that engine. You do not need to be in the cockpit for a visual confirmation because if the jet tells you that you have an engine fire, then you treat it as real. If you have a fire elsewhere in the plane, then I'm not sure there is anything that can be done at all.
There are a plethora of systems that can take control of an aircraft to prevent crashes, stall conditions, over-Gs, hell even automate take-offs and landings if we wish to do so. Systems like these are not typically installed or used AFAIK, but the technology exists and it can cut out a lot of human error.
And last but not least, if you lose one of these planes, the risk of death or capture of the pilot is zero.
I'm not for or against unmanned aircraft. I just wanted to get these points out in the open.
