I've currently got Fios and the Actiontec MI424WR router that I think it standard with Fios for everyone. Well, I'm out of ports, and need to add some. I'm wired via Coax, and running ethernet cable through the house isn't really a viable option.
That being said, I've got two desktops, 3 laptops, Vonage, and soon to add NAS option to my network. Until now I've just run 2 laptops wirelessly, but with adding NAS I need more ports. Based on reviews (mainly on newegg), I was looking at getting the D-Link 8-port 10/100/1000 switch (DGS-2208). Though I am open to other suggestions based on any personal experience (need 8 ports though).
My real question is two fold. One, is it as simple as running a network cable between the switch and actiontec router and just plugging everything into the D-link switch? And two, if it si that simple, do I use a regular network cable or do I use a crossover cable between the two routers?
I guess lastly, though I think I know the answer, to mazimize the gigabit switch, do I need to use Cat6 cables between all the devices, or will CAT 5e work just as well?
Thanks alot, I've searched and found bits and pieces of answers to my question, but figured with as helpful as this forum has been for the last 9 years, best just to lay it all out exactly to fit my situation to get a definitive answer. (and yes...9 years here, and I'm this much of a network noob. Never really had a need to run anything other than my own computer, maybe a laptop...then you get married, have kids, etc etc...and all of a sudden I'm running a small university here )
Thanks in advance guys for your time.
