I have this motherboard (X58, EVGA 131-GT-E767-TR): http://www.newegg.com/Product/Product.aspx?Item=N82E16813188068
It is paired with an i7 950 and the following RAM (G.SKILL 3 x 2GB DDR3 1600): http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225
I've decided up to upgrade my RAM so I purchased this (Mushkin 2 x 8GB 2133):http://www.newegg.com/Product/Product.aspx?Item=N82E16820226434&cm_re=mushkin_blackline_16gb-_-20-226-434-_-Product
I then thought to myself, wait, is this even supported by my chipset? Answers I've found online are mixed. The spec sheet on the mobo says it only supports 4gb/dimm, but I don't know if that's something that could have changed via bios updates. I'm also not sure if any speeds past 1600MHz are supported. And finally, did I make a mistake in buying a dual channel kit when my mobo supports triple channel? I thought this would be a simple upgrade but now I'm swimming in questions. Help?
