BecauseScience
- Oct 9, 2005
I have a Toshiba Qosmio X70-ABT2G22 on the way. I was forced to go with a gaming machine due to other features I need but I have no use for the GTX 770M. Will the 770M be on a card that I can remove if I only plan to use the i7 gpu? It's an Optimus setup.
There are two 2.5" disk bays, one internal mSATA, and an optical bay. Is it a good bet that all of those are on SATA III? The chipset is HM86 which has four SATA III and two SATA II. There's no eSATA port on the laptop.
My plan is to pull the included hard disk and install two ssds. I have one 2.5" ssd on the way and I'm wondering if it's safe to order another 2.5" ssd or should I wait to verify that both 2.5" bays are in fact SATA III.
I've never owned a gaming laptop before so I'm clueless on these discrete gpus and extra bays.
