Some months ago, I purchased a Sony VAIO S15 notebook. This computer features a 15" 1080p LED IPS screen. Yes, the screen looks gorgeous, but after I had used it for a while, I experienced some mild eye strain. The screen's default PPI is quite high (141), so I set the scaling in Windows to 125%, which resulted in a more convenient 113 PPI. However, I'm still experiencing some mild eye strain after using it for some time. Recently, I bought an external 23" 1080p LED IPS monitor: the LG IPS235P. Unfortunately, I'm experiencing the same issues using this new monitor. The eye strain is mild, I don't get headaches or something like that. Nevertheless, it bothers me, in particular as I don't understand what's the cause.
It doesn't seem to be related to PWM: I did the camera test from http://www.tftcentral.co.uk/articles/pulse_width_modulation.htm and it turned out that the Sony's screen is not using PWM to reduce its brightness (did the test at 40% brightness). (The LG does use PWM to reduce its brightness.) It seems not to be related to LED either: I have used the 10" LED (TN) screen from my Samsung NC10 netbook quite extensively, without experiencing any issues. My tablet's 10" screen is also LED and I don't experience any eye strain using it. By the way, this screen is IPS, so it seems not to be related to IPS either.
Does anyone have a clue what could cause this mild eye strain? I'm stuck. As a final note, my previous display was a Samsung T220 CCFL TN monitor (and guess what, no issues).
