Got this put together yesterday. What a bitch.
Took out the original EK silent 120mm, 1600RPM fans that were above the rad. Replaced them with NF-F12 iPPC 2000.
Put the EK silents at the bottom after cleaning them from 3 years of use without touching them for 3 years. Blew and vacuumed the rad, which wasn't to bad at all. Pics below.
NF-F12 iPPC 2000
EK silents, after and before.
Getting silents mounted. Upside down shot first pic.
Misc.
All done.
While ago, week or so I ordered the wrong pump bracket to move my pump to add in the stock second hdd cage.
Fabricated the bracket, its lopsided because the last drilling hole, drill bit slipped into a stock mounting hole, shifting both brackets.
Before.
and now
Hope you enjoyed viewing.
The water cooling setup and case would be changed out, same with new everything but I just can't afford it.
I've been building this PC starting from the board and a i3-2100 back in 2011 to now. Specs are in sig.
NF-F12 iPPC 2000
Misc.
All done.
Before.
and now
