Noctua NF-A12x25 PWM, still the best 120mm silent fan?
mikeo
So have a few older Noctua fans and need to buy at least 3 more for a 3x360 radiator configuration, but debating just replacing them all with Noctua NF-A12X25 PWM fans. Is there anything better performing out there in a 120mm option at that noise level or are those still considered the best?
tophlor
I just purchased three of these for my new build to augment the ones I already had. Awesome, quiet and well build fans!
Reactions: mikeo
Monkey34
+100 IMO for Noctua. AFAIK they're still tops for quiet fans.
I just modded a case to replace 80mm intake fans (had space for 4, but 3 installed) with a NF-A14-FLX 140mm.
I can barely hear it running...it's just under 20db at full speed and I haven't even tried lowering the rpm's yet.
Reactions: mikeo
Vengance_01
Look at there redux fans. Bit cheaper but still great fans. Could use these for case fans and get the best for radiator
Mav451
I don't think I'd invest in any of the old guard (Nocuta P12, Noctua P14) in 2020. These fans undervolted fine, but were never top performers - even less so now, especially if they're dealing with radiator fin density (vs. the typical air cooler tower). I added the "Noctua" part, because Arctic Cooling also has P12 and P14 fans on the market, though the redux part probably reduces that confusion lol.
Vengance_01
They are still good fans for case fans. I used the redux fans in my build including my heatsinks for CPU cooler... Have no complaints with there performance
