Hi All,
As the title says, can you please advice on which fans are best for attaching to the GPU hestsink. Noise is the biggest priority with thermal performance being a close second.
2 x Noctua NF-A12x25
https://noctua.at/en/products/fan/nf-a12x25-pwm
Or
2 x Noctua NF-F12 PWM
https://noctua.at/en/nf-f12-pwm-chromax-black-swap
I know the NF-A12 is regarded as the best, if not one for the best, all round fans money can buy, but I wasn't sure if the nf-f12, made for static pressure, would be better when zip tied directly to the hest sink (to eliminate any gap between hest sink and case fan locations).
The will be a Nh-u9s cooling the cpu with a second matching fan mounted to either the rear fo the case or the other side of cpu cooler.
https://noctua.at/en/nh-u9s-chromax-black
I am considering having both the gpu and cpu both extracting. Alternively having the GPU intake and cpu extract, but I was concerned about hot air from the gpu affecting the psu and cpu. I welcome thoughts on this as well please.
Thanks for the help
Or
Thanks for the help
