No Trunks in Trunk Membership
Modus
I have a procurve 1810G-24 Switch and i have created 4 trunks on the trunk configuration page, when i go to the trunk membership page i don't see any Trunk ID's in the drop down menu. It just says none, why is that and how can i fix it?
Liquidkristal
are the trunks active, as in plugged into another switch with a similar configuration?
They probably won't show until they are active.
Modus
Nope that wasn't it. Unfortunate the 1810 is web GUI only & i was using IE11 to administer it, i had a thought to try another browser then i could see the trunks in the trunk id field. So i went back to IE then put in the ip address into the compatibility view settings then it worked in IE also.
