No sound in Mafia 3. I freakin give up
Discussion in 'PC Gaming & Hardware' started by MelonSplitter, Oct 22, 2016.
  1. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    I have the digital deluxe version of Mafia 3 and for the love of me cannot get the voices to play in cutscenes or in game. All other sounds play fine. I think I have done everything that is possible within my realm of computer skills trying to fix this including, going to control panel and changing sound to stereo or 2 channel and then reinstalling the game, twice. Please, any help would be appreciated. 2K forums are no help.
  2. pendragon1
    pendragon1 [H]ardForum Junkie
    13,998
    Oct 7, 2000
  3. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    yup. I've never had this type of problem with a game install. Usually I could figure shit out myself with Googles help, but not this one. Going on 2 weeks now!
  4. Q-BZ
    Q-BZ [H]ard as it Gets
    18,290
    Sep 28, 2007
    Stray idea: Make sure your sound settings are no higher than 48000 KHz.
    I put this without quotes in the search engine (Google in this case): "mafia 3 PC no sound"
    I got a bunch of hits on the first page but I'm betting you have already been through all of that.
    Someone said it might be surround settings and the voices are being sent to something that doesn't exist or some such. It almost seems like it as specific as your case is.
    Make sure any dynamic range nonsense is disabled. Anything like that.
  5. KickAssCop
    KickAssCop [H]ardness Supreme
    6,576
    Mar 19, 2003
    Go to sound options and set it to barebones software sound. Then try and report back. If you are using headphones it can be a bad cable or headphone jack.
  6. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    Just tried lowering sound to 46000Khz to no avail and disabling surround and such. Still not working. Looks like I'll have to wait for Hangar 18 to release another patch and go from there. Thanks though
    Vegas P11 likes this.
  7. Q-BZ
    18,290
    Sep 28, 2007
  8. pendragon1
    13,998
    Oct 7, 2000
    that's a good point. disable any and all overlays that you might have, steam, origin etc
    Q-BZ likes this.
  9. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    Thanks guys. Still nothing. I will try an update my motherboards sound driver if possible and get back to ya.
    Q-BZ likes this.
  10. DrLobotomy
    DrLobotomy [H]ardness Supreme
    6,300
    May 19, 2016
    Maybe it is missing one of those C+ distributables or the DirectX ones.
    Q-BZ likes this.
  11. pendragon1
    13,998
    Oct 7, 2000
    that could be it too. check the install folder for a "support" or "_CommonRedist" folder and install everything in it.
    Q-BZ likes this.
  12. KickAssCop
    6,576
    Mar 19, 2003
    Verify cache maybe? lol.
  13. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    I've tried all of these "fixes" to no avail. I remember I had a problem with Far Cry 3 where I could not open any doors in game or something like that. I tried everything including reinstalling my OS. I was using Win 7 at the time.
    That didn't work either. What did work was installing Win 8.1. That worked like a charm. I know this doesn't have anything to do with this problem, I'm just saying how fickle these problems can be
    Q-BZ likes this.
  14. w35t
    w35t [H]ard|Gawd
    1,114
    May 29, 2013
    Damn that sucks lol, be sure to let us know the fix when and if you find one.
  15. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    Still have not gotten this sorted out, but I will, I promise. Even though these types of problems can be downright maddening, we still love the challenge of figuring this shit out. And when we do we're like, Fuck Yeah!!
    Q-BZ and Domingo like this.
  16. Domingo
    Domingo [H]ard as it Gets
    17,235
    Jul 30, 2004
    Problems like this can be both maddening and satisfying...assuming you can find that one-in-a-million quirk that fixes the issue.
    I'm still looking for a way to prevent the Crew from going into bullet time at random.
    MelonSplitter and Q-BZ like this.
  17. pencea
    pencea [H]Lite
    74
    Jun 21, 2016
    Just bought this game and experiencing exactly the same problem as the OP. No sound nor voices during in-game or cutscenes....
  18. Shantarr
    Shantarr Limp Gawd
    258
    Mar 28, 2016
    Random ideas:
    Do you guys have teamviewer or audio repeaters installed and running in the background? If so, disable or uninstall
    Do you have Additional audio devices (to include monitor outputs)? If so disable them (just as a test)
    Do you have a 5.1 or greater sound system? Plug in only Front L/R and test again
    Do you have ANY positional audio on? Disable it
    Do you have Nvidia shadow play, or any other recording software installed? Disable it
    Lastly, test with a USB audio device, this will have it's own sound processing and will possibly rule out your system as the issue at all and pin it directly on the game.
  19. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    Update: Nothing has changed. I still have not been able to fix this problem. The only thing left for me to try would be to install my older copy of Windows 7, which I don't want to do, or install my new copy of Windows 10 that's been sitting on my desk for about 4 months, which is also something I don't want to do. I've gotten real comfortable with my Windows 8.1 and haven't had a reason to upgrade until now. Not really a reason but a little incentive if I can play this game. Its not like I don't have anything to play because I do. I've been loving Resident Evil Biohazard. I'll give another update later if anybody gives a shit.
  20. Q-BZ
    18,290
    Sep 28, 2007
    Damn dude! I feel for you. I'm genuinely perplexed and mystified by this.
    I saw they had put a game update out last week or some such? Obviously didn't make any difference? :(
    Have you contacted 2k Tech support or been on their forums or anything? I can't believe you'd be the only person with a problem like this since I'm assuming you've had zero problems with any other games and programs?
  21. The Donut
    The Donut 2[H]4U
    3,086
    Jan 28, 2003
    Sounds silly - but it's possibly dialog is being forced to the center channel and you simply don't have one.
  22. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    I thought when in Stereo mode that All audio is forced through the L and R speakers or headphones. But what do I know. I might go to Best buy and buy a cheap sound card with 5.1 audio. I use a Logitech 2 speaker 1 bass setup being pushed by my EVGA x58 motherboards audio. Realtek HD I believe.
  23. vegeta535
    vegeta535 2[H]4U
    3,263
    Jul 19, 2013
    This game had so much potential. The first few hours were awesome then it fell flat on its face.
  24. ryuen
    ryuen Limp Gawd
    326
    Nov 2, 2005
    I had a similar issue with SWTOR and that was due to the 'GX' option (a kind of soundblaster EAX emulation) being enabled in the control panel of my Xonar soundcard.
    Does yours have an EAX compatible/emulation mode? Might want to turn it off and check.
  25. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    No it does not but thanks.
  26. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    I have 0 responses within 2K forums and 2K support gives me the vanilla answers that I've already tried such as Verifying game cache, Reinstalling DirectX and Vcredist and last but not least, try unplugging my controller.
    Q-BZ likes this.
  27. djoye
    djoye 2[H]4U
    2,779
    Aug 31, 2004
    Are your speakers connected using an analog connection (typically a green-colored connector)?
    First thing to do:
    1. Right-click on the speaker icon in your system tray (bottom-right of screen) and click on "Playback devices"
    2. Find the output device your speakers are connected to, typically the one set as default with a green check mark, right-click on it and select "Configure speakers"
    3. Select Stereo, click Next -> check the "Front left and right" full-range speaker box, click Next, then click Finish
    Next step:
    1. While in the same Playback device area, right-click on your default output device and select "Properties"
    2. Go to the Enhancements tab and check "Disable all enhancements"
    3. Click the OK button and test your game
    Other:
    If you have the Realtek audio control panel software, make sure your speakers are set to stereo.
    The only reason for getting the effect where voices are quiet would be that the game thinks your PC has 5.1 speakers connected. Ensure that your speakers are connected to the front L/R audio output on the motherboard (if that's what you're using) and ensure that your audio output device is set to full-range stereo; if it is set to anything like 5.1 or 7.1, you will lose audio.
    Q-BZ likes this.
  28. H-street
    H-street [H]ardness Supreme
    4,538
    Feb 25, 2005
    Just a quick trouble shooting. Watch the audio output meter for windows sound and see if you get "metered" volume change when you think dialog is being spoken.
    This should tell you if the sounds are even making it to the audio device in windows .
    If not it's a game problem and then you can start looking at libraries etc... if it is and you aren't hearing it then it's an obvious problem with your audio hardware layer somewhere
    Q-BZ likes this.
  29. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    djoye, everything is and was set up just like you suggested to no avail. Thanks
    Q-BZ likes this.
  30. Q-BZ
    18,290
    Sep 28, 2007
    I'm so perplexed here. *scratches head*
  31. AceGoober
    AceGoober Live! Laug[H]! Overclock!
    21,803
    Jun 25, 2003
    MelonSplitter
    What is the specific model of motherboard you have? I have a longshot idea of what may be happening but I need to research the board first.
  32. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    Evga X58 Sli LE
  33. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    Evga X58 Sli LE
  34. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    How do you enable sound metering in game?
  35. AceGoober
    21,803
    Jun 25, 2003
    MelonSplitter
    I've ran quite a few searches trying to find out what the specific audio I/C is on the X58 SLI LE but have come up empty handed. Can you look at your board and see if you can read the lettering on the chip?
  36. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    I assume you mean the Realtek chip number. I'll have a look and get back to you. Thanks Ace.
  37. H-street
    4,538
    Feb 25, 2005
    Just run the game and open the windows volume panel and you will see the metering Next to the game in the volume panel
  38. Nanogrip
    Nanogrip Limp Gawd
    442
    Dec 4, 2016
    If it's voices only, then it might be a game issue. Maybe the voices are not in english? Or with some games, you can opt not to install additional languages, maybe that has something to do with missing voices.
  39. MelonSplitter
    MelonSplitter Gawd
    860
    Aug 6, 2006
    I just did this and there was metered sound with the intro and in game music, but once the beginning narration started with the priest I believe, I could not hear his voice even though the subtitles were playing. The sound and the metering stopped
  40. horrorshow
    horrorshow [H]ardness Supreme
    7,211
    Dec 14, 2007
    Pick up a Xonar DG ($30) and use the Xonar Unified Drivers.
    It fixed all my gaming issues due to my Realtek mobo sound (Realtek ALC888)....
