No signal going to monitors? help please!
midas06
When I start my PC, which has 2 monitors and runs on XP, it shows the normal booting sequence, then the windows XP loading screen, then no signal goes to either monitor once Windows starts. This has never happened before today.
Help to fix this would be greatly appreciated, cheers.
Hit F8 and try VGA Mode, that should load windows generic VGA drivers at something like 800 by 600. If you then get video check your screen resolution and set it to the native resolution of your monitor. If that doesn't work you may have to re-install your video drivers. If your video card has a TV out function make sure thats not enabled.
