Hi, I use MB Gigabyte GA-Z68X-UD3H-B3 (rev.1.3) and Gigabyte GTX780GHz for about one year (there was HD6970 before). Suddenly one day there was no signal on monitor after switched computer on, when switched to onboard video and checked device manager (GTX780), there was message "Code 43: Windows has stopped this device because it has reported problems". I somehow found position when card works, the card have to be taken little bit up and left (so it "stays" on the screw for slot beside) as can be found on picture. It was working for several days, then while gaming black screen and strange sound, restart, working fine for several minutes, black screen again, restart, no signal. Open case, took out the GTX, put back again (again stays on screw for slot behind), it worked! But I didnt want to have black scree again, so I moved the GTX to PCIex8 slot and it works just perfect for several days (normal position).
Did anyone met same issue? Do you please know what could be the problem? I tried to look at PCIex16 slot but didnt see any issue.
