I just bought an Asus M3N78-VM off the forums and I'm having a problem with the HDMI. If the computer turns on with the tv off, I change the inputs or turn the TV off there I get a no signal message from the TV when I try to go back to watching the HTPC. I used to have this problem with my 780g board and was able to use hdmiOn to reset the EDID signal before a driver update fixed the problem but hdmiOn does not work with this board. So really the way I've been able to get the signal back is to either restart the computer or put it to sleep with my remote and then wake it back up with the remote.
Does anyone know a way of fixing this problem? BIOS setting, certain drivers, ritualistic sacrifice?
