No output on GTX 960
Discussion in 'nVidia Flavor' started by BloodDonor, Jul 10, 2015.
  1. BloodDonor
    BloodDonor Limp Gawd
    315
    Dec 5, 2009
    Bought a new Gigabyte GTX 960 as my 560 is getting a little long in the tooth. Trouble is, there is no output (it powers up). Tried DVI, HDMI, and DVI to VGA. (Tried 2 different monitors), all say no input.
    I have an Asus H87m-e, a 700w Silverstone (more than enough power), and the 960 only requires 1x 6 pin for power vs the current 560 which requires 2x 6 pin.
    I have tried the latest bios, removed the CMOS battery and cleared it, no joy.
    I've reseated it several times
  2. defaultluser
    defaultluser [H]ardForum Junkie
    12,541
    Jan 14, 2006
  3. BloodDonor
    315
    Dec 5, 2009
    I've pulled it out and put it back in about a Dozen times (it's actually card #2, the first did the same and I thought it was DOA... it tested fine though at the company, but they gave me a new one...
    (I'm in New Zealand, and the store is at the other end of the country...)
  4. defaultluser
    12,541
    Jan 14, 2006
    Boy that sucks!
    Did you try a different 6-pin power lead? maybe it's broken.
    The only thing I can think of is you not supporting the UEFI BIOS on these new Maxwell cards, but you have that covered with the H87 motherboard.
    Maybe try an AMD card next time you venture to the store? You might have a corner-case compatibility issue with this one model of card. PCIe in my experience is is a bit more picky than old PCI bus was. Still works 95% of the time...but you never know.
    Hope you don't have to drive north south, that's hundreds of miles :(
    EDIT: had a thought: why don't you take your PC to the store, and try out the card there? IT would mean you only have to make one more trip. Ask the owner if you can do that. It's a PC parts store, it should have a tech center.
  5. BloodDonor
    315
    Dec 5, 2009
    The store is 1640km~ away... :(
    They couriered the replacement card to me...
    Ive tried both 6 pin power connectors on my PSU, and also a double molex to 6 pin adaptor... neither made a difference
  6. Ultima99
    Ultima99 [H]ardness Supreme
    4,890
    Jul 31, 2004
    Do you have a friend, neighbor, or relative with a PC you could try the card in?
  7. BloodDonor
    315
    Dec 5, 2009
    Took it around to a friend who fixes PC's... he tested it in his PC, works fine, tested his card in mine, it didnt like it (970).
    It doesnt even see it in the BIOS... time for a new board
