DeadlyAura
- Jun 6, 2005
I'm having a serious problem with Windows 7 on my desktop PC.
Basically, I shut my PC down the other day because it was just too fucking hot in my room to keep it running. When I booted it up the next day, no more internet connection.
Network status: Identifying... No Network Connectivity
This has happened before, so, I uninstalled my NIC drivers, rebooted, Win7 re-installed them, and it worked perfectly. However, this time, that didn't work so well. Every time I tried to disable or uninstall the drivers, the system would lock up and require a reboot. Only ONCE was I able to uninstall the drivers successfully, but it still did not help.
I've tried resetting the TCP/IP stack, and a couple other fixes I've found around the net, but nothing seems to work. I also tried restoring my router to factory settings, and that doesn't work either.
Every PC in my house works just fine on the internet, even when attached to that particular cable.
Any suggestions?
Any suggestions?
