No longer see NICs in Network Connections
COKE CAN
Under Windows Server 2003 Enterprise Edition
Verified that the drivers are installed (reinstalled). They (the NIC connections) no longer show up in the Network Connections. They were there.
Could a registry value have been altered? If so, where should I look?
Would like to get this resolved in a timely fashion, but I am stumped.
This happened while running a security lockdown script (created by our security officer) remotely.
Nenu
[H]ardened
I had the same problem after applying a security patch on XP.
It turns out that permissions on network objects were changed so that I didnt have permission to view them as an Administrator and the Admin account couldnt either.
Microsoft patched the patch :)
I suspect a similar issue caused by that patch you applied.
Given that the script seems to have changed settings on your local PC rather than through a network group policy at logon, I imagine they are reversible.
However you will no doubt be violating company policy and could risk your job if you do.
