pgwalsh
- Mar 21, 2005
Hi all.
I've been trying to overlock my 2600k and can't seem to do it properly or something is being reported wrong. I don't know if it's my BIOS or my reporting tools. What's happening is I'm setting up my CPU frequency etc to 4.4Ghz and I have turbo off, but my software is reporting 5.9Ghz. I've tried several different apps and they all report the same. I'm using an Corsair H100 cooler. I'm running Linux Mint 17.
I've read a lot of different forums including this one and followed what others have done, but then I get this crazy reporting of 5.9. I feel like the BCLK and Turbo are not behaving properly in the bios. At 4.3 idle the cooler fans are normal, but once I start encoding with Handbrake, that's when the CPU spikes and shows that it's going to 5.9. However at IDLE I see it at 1.6.
Here are the specs:
GA-Z68XP-UD3 with U1J(UEFI BIOS)
Intel Core i7 2600K
Coarsair H100
Corsair Carbide Series 400R Mid Tower
Corsair Vengeance Low Profile PC3-12800 16GB
Samsung 840 SSD
Advanced Frequency Settings:
CPU/PCIe Base Clock 100.00MHz
Processor Graphics Clock: 1350 Auto
CPU Clock Ratio: 34
Extreme Memory Profile: Disabled
System Memory Multiplier: 13.33 Auto
Memory Frequency: 1333MHz
Advanced CPU Core Features
Internal CPU PLL Overvoltage: Enabled
Intel Trubo Boost Tech: Disabled
CPU Core Enabled: 4
Hyper-Threading: Auto
CPU Enhanced HALT (C1E): Disabled
C3/C6 State Support: Auto
CPU Thermal Monitor: Auto
CPU EIST Function: Auto
Advanced Voltage Settings
CPU Vcore: 1.350V
Dynamic Vcore (DVID): 0.000V Auto
QPI/Vtt Voltage: 1.050V Auto
CPU PLL 1.805V
System Agent Voltage: 0.935V
DRAM Voltage: 1.500V Auto
DRAM Voltage Referencee: 0.750V Auto
DRAM Termination 0.750V Auto
Data Reference (CHA) 0.750V Auto
Address Reference *(CH A) 0.750V Auto
Data Reference (CH B) 0.750V Auto
Address Reference (CH B) 0.750 Auto
BIOS Features
Limit CPUID Maximum: Disabled
Execute Disable Bit: Enabled
Intel Virtualization: Enabled.
The bios is reporting the following:
BIOS Version U1J
BCLK: 100.31MHz
CPU Freqency: 4312.73MHz
Memory Frequency: 1337.58MHz
CPU TEMP: 37.0 C
Any guidance or help is appreciated.
Here are the specs:
Intel Core i7 2600K
Coarsair H100
Samsung 840 SSD
CPU Clock Ratio: 34
CPU Core Enabled: 4
CPU Vcore: 1.350V
CPU PLL 1.805V
BIOS Features
BIOS Version U1J
BCLK: 100.31MHz
CPU TEMP: 37.0 C
