DGMurdockIII
- Jan 16, 2015
I looking for suggestions on some nintendo switch accessories like batteries case, joy con grips, headphones with microphone any help would be appreciated
Pro Controller if you have any desire at all to play docked
Screen protector
Some sort of case for the games/system, if you plan on taking it mobile
9 months later I'm still waiting for a decent travel case that is big enough to hold the AC adapter but isn't the size of a trunk or backpack. There are lots of good smaller ones (and a couple huge ones), but nothing medium sized. Amazon's is probably the closest, but it's big enough where it's meant to hold the dock, too.
The fact that the stock AC adapter is a monster doesn't help
When I went to Europe over the summer I just didn't bring the AC adapter. When the Switch ran out of juice, that was that.
Can u list some brands u would recommend
For the AC adapter you're better off going with a USB solution. As long as you get any USB charger that is doing 5v/2A it's enough to power the Switch without the battery draining. You'll need a charger that supports USB-PD if you want enough wattage to both play and charge at the same time though. Either way these style chargers are smaller then the official Nintendo one and make for better travel. You can even use a small 5V/1A USB charger like the Apple iPhone charger if you want and while this only feeds 5 watts it's enough power to extend playtime by a huge margin, and while the switch is in sleep mode is still able to charge it pretty fast.
Bottom line is that while traveling I don't bother bringing the massive official power adapter. I just bought a USB A - C cable and use my small iPhone 5w adapter, and most planes have 5V/1A USB power jacks built into the seats as well.
