NFSU Patch
mrurmil
I want to play online but I hear that the patch really messes up the game. What known problems does the patch cause? Should I bother getting it?
The only thing that I have noticed is that AA no longer works (screen goes blank during play) and the motion blur for turbo or fast speeds causes the screen to go black. The solution until the next patch is not to use AA and turn of motion blur under video settings.
They need to fix this. The holiday is over.
If you turn off the light trails option the motion blur works...
