ok, so i install this stupid pos game, and in the game, whereever theres supposed to be a number or letter, ITS JUST A FUCKING BLOCK. omfg im so pissed there better be a fix.... please help
first off if it's a stupid pos game i see no reason for you to be worried about it but, is it gonna stay or will it change to 1280x1024, and yes i have tried reinstalling.
what does that mean, mine runs fine at 1280x1024, are you unable to switch it or what, AND do you have an english version, the blocks might be not having the language you installed it in on your computer...
There was something similar with GTA3, and it was something that had to do with getting a patch from MS. If you're running XP, get SP1, see if that helps.
Otherwise reinstall windows and see if it is still goofy.
It's something with the ATI drivers. My brother had the same problem with is 9800 pro. I can't remember which drivers work though, I don't have an ATI card. But that is the problem.
doi! i didnt even think about drivers! i'll try going back to the 3.7's (those are the only ones i really like anyway)
and bananadog... just a word of advice... when you try to help someone... please actually try to make sense. i have no idea what the hell your talking about
