If you go to update your board and have raid, I recommend you DONT do it. My system would not boot into windows. It appears that I am not the only one that has this problem as well. You can check out some other forums and see some other occurrences...
http://forums.amdmb.com/showthread.php?s=&threadid=283639&perpage=15&pagenumber=1
Just thought you might like to know b4 you take the plunge...
