Newegg Refurbished: PowerColor Radeon RX Vega 64 LC $349.99
Discussion in '[H]ot|DEALS' started by Gulkor, Apr 23, 2019.
  1. Gulkor
    Gulkor [H]ard|Gawd
    1,260
    Jan 26, 2007
    Newegg has Refurbished: PowerColor Radeon RX Vega 64 LC $349.99
    Refurbished:
    PowerColor Radeon RX Vega 64 DirectX 12 AXRX VEGA 64 8GBHBM2-3DHW 8GB 2048-Bit HBM2 PCI Express 3.0 x16 CrossFireX Support ATX Video Card , https://www.newegg.com/Product/Product.aspx?Item=14-131-745&Ignorebbr=true
    Wondering if i should pick one up,
    From reviews with freesync you can do 4k@60hz
  2. THUMPer
    THUMPer 2[H]4U
    3,041
    May 6, 2008
    Pretty happy with mine.
  3. Gulkor
    Gulkor [H]ard|Gawd
    1,260
    Jan 26, 2007
    I have 75" 4k /w freesync is reason i asked.
    What settings do you run on 4k? And what kind overclock's do you get with yours?
  4. bobow
    bobow n00b
    23
    May 22, 2017
    Just like the cheap (about to be discontinued) 7990 and 295x2 I've passed up before I'm assuming these will only be available used after this. Want to get it but next gen is so close, and Vega is still a heat/power monster.
  5. ccityinstaller
    ccityinstaller [H]ardness Supreme
    4,229
    Feb 23, 2007
    I played a lot of games with my 64 OC'd to 1750/1150ish at 4k. It's about on a par with a highly Factory OC'd 1080 to a stock 1080ti (*IF* THE GAME is AMD Optimised)...VEGA 1.0 REALLY needs a high HBM clock to overcome it's limitations but it's a great card for the price. It's guaranteed to be a great die and Samsung HBM which clocks to the moon! Just keep your HBM temps under 70c for long term use.
    N4CR likes this.
  6. ccityinstaller
    4,229
    Feb 23, 2007
    You can make VEGA perform better then sby review with 2/3rd of the power with a few tweaks.
  7. Gulkor
    Gulkor [H]ard|Gawd
    1,260
    Jan 26, 2007
    I might have jump on it,
    I sold my radeon VII for good cause, and been looking for something kinda close.
    Is warranty worth it? It does say no returns and 30 day exchange only and 90 day warranty
  8. THUMPer
    THUMPer 2[H]4U
    3,041
    May 6, 2008
    I play at 1440p. I set a clock speed of 1732 with an undervolt. The card is 1750mhz default but voltage is too high so it never reacheds that speed. I can run at 1750 with an undervolt, but it can't maintain that speed unless it stays under 45c. It's usually around 50c.
    HBM speed helps more than core clock though I can get 1150mhz HBM, which helps
  9. bobow
    bobow n00b
    23
    May 22, 2017
    No idea what you're talking about here but I know about the UV tweaks. 250W is still a ton for southern summers and I'm still betting on new arch 7nm to get that down from either company (now that Nvidia finally supports Freesync to some degree).
  10. ccityinstaller
    4,229
    Feb 23, 2007
    Sorry was a mobile typo. I meant to say "better then "nearly" (since GN did undervolt etc) any review".
    I spent 34 yrs living in an area with 95-110F 100% humidity summers and had no issues cooling even tripled Overvolted 290s with the magic of AC.
    You guys that think the insane power different of 50W (say between a 200 and 250W card) is Earth shattering are kind of amusing. It's literally less power then a 60W light bulb and I bet you used to use plenty of those before CCFL AND LED no?
    You are correct that we are all waiting for new 7nm+ cards, or even the new "6nm" density improved process coming soon but for 99% of us, it is for what matters most: performance. If you want a card that pulls a certain amount of power, then buy that but you aren't going to get a 2080TI in a 1650 power envelope in the next 10 years unless Si goes the way of the DoDo bired.
    (I mean zero offense, it's just funny to see the power bashers arrive in AMD threads but defend Nvidia and Intel on their rampant power uses which ezceeed their marketing numbers by 2-3.5x)
    Jim Kim and N4CR like this.
  11. Gulkor
    Gulkor [H]ard|Gawd
    1,260
    Jan 26, 2007
    I dont mind power useage, i mean 4k is hard gpu, Im thinking picking this up, its with-in 10% of Radeon VII, that card made everything smooth.
    I judt dont want regret it, I'm going buy WB for either this Vega 64 LC or go back and buy radeon VII
  12. Dan
    Dan [H]ardness Supreme
    7,475
    May 23, 2012
    ugh, its OOS. I would have bought it =[
  13. Starrbuck
    Starrbuck 2[H]4U
    2,472
    Jun 12, 2005
    I bet they had one.
  14. Gulkor
    Gulkor [H]ard|Gawd
    1,260
    Jan 26, 2007
    Im waiting for it come back in stock. I should've bought one, its been in and out of stock,
    Im sure momday theyll have more
  15. Dan
    7,475
    May 23, 2012
    hmmm, Might be worth to sell my xfx 56 and scoop this up for the 100ish bucks
  16. viivo
    viivo [H]ard|Gawd
    1,288
    Sep 7, 2005
    How long did it last? Gouging resellers normally jump on these deals and clear out the stock within minutes. If they do come back in stock, any person who just wants one to actually use will have to be lucky to get in before the bots buy them out again.
  17. Gulkor
    Gulkor [H]ard|Gawd
    1,260
    Jan 26, 2007
    I didnt get one, They were in stock for whole day almost, then got some more took few hours, then went out of stock, if they come back in stock I'll pick one up, or get Ref vega 64 /w waterblock and o/c it
    I was going do vega 64 /w waterblock or radeon VII /w waterblock,
  18. Archaea
    Archaea [H]ardForum Junkie
    9,431
    Oct 19, 2004
    It’s a nice card for $350
