[Newegg]EVGA Z170 FTW 120usd AR (Compatible with Kaby Lake)
I like that board but its extended atx. It wont fit in a lot of cases. Good deal though.
Edit by Mod:
You are incorrect sir.
Physical Spec
Form Factor
ATX
Dimensions (W x L)
12.0" x 9.6"
It says eatx on the specs. I didn't think it would fit in a atx case. My mistake
Specs
  • Intel® Z170 Chipset
  • SLI - Up to 2 Way SLI + PhysX
  • 8 USB 3.0, 2 USB 2.0
  • 4 DIMMs, dual channel DDR4, 3200 MHz+, up to 64GB
  • Solid State capacitors
  • Form Factor - EATX
  • Intel NIC (i219 PHY)
  • Realtek 8 channel audio + optical out
  • M.2 Key M up to 32GB/s
  • Replaceable BIOS Chip
those arent the true specs. newegg should have used some other source
Specifications
  • Chipset – Intel Z170
  • SLI – 2-Way + PhysX
  • SATA – 6 SATA 6G
  • RAID 0, 1, 5, 10, JBOD
  • USB – 8x USB 3.0 / 2x USB 2.0
  • Memory Support – 4 DIMM Dual-Channel DDR4 3200MHz+ (up to 64GB)
  • Capacitors – POSCAP/Solid State
  • Ethernet – 1x Intel® Gigabit NIC
  • Audio – 8 Channel High Definition Audio + Optical
  • Display Outputs – 1x DP 1.2, 1x HDMI 1.4
  • Fan Headers – 7 (2 PWM, 5 DC / PWM)
  • PCB – 6 Layers
  • PCI-E Slot Arrangement – 1x16, 2x8+1x4+1x1
  • NVMe Support – Yes (PCI-E)
Form Factor
  • ATX Form Factor
  • Length: 12in - 304.8mm
  • Width: 9.6in - 243.8mm
Looking at the screw holes near the RAM slots in the pics easily shows that it's ATX form factor and not EATX.
thats an atx board. You can easily tell by looking at picture.
You can tell if it is ATX vs EATX by looking at the right side screw holes. ATX pcb ends at the screw hole whereas EATX extends beyond that. Look at the actual board and it becomes obvious.
