[Newbie] How do you run Orthos on both cores?
Xophile
Hi!
I'm getting my E6850 today and some people write that you should run two different instances of Orthos to stress both cores.
But when I look at screenshots in various overclocking threads it seems that Orthos can stress both cores with only one instance running. Which is correct?
Thanks!
Orthos will run just fine on a dual-core.
It's quad core that won't work. :)
to verify its running on both cores just CTRL+ALT+DEL and go to performance see if it's pegged out on both cores.
