Newbie graphics card question GTX 1070
smithco
Hi Folks,
I am new to the site, so apologize if this is a duplication. I did a bit of a search, and couldn't find specific answers.
I am not a gamer, but instead use my laptop for CAD work, including full color renderings, "fly-thrus", etc, and I want to maximize that process.
Currently have a laptop with these specs:
Intel i7-8750 CPU @ 2.2GHz
16GB RAM
500GB in C drive
2TB in D drive
Invidia GTX 1070 card
What would a good upgrade be (to any of the components if applicable), but specifically to the GTX 1070?
Thanks in advance for any recommendations!
Cole
deruberhanyok
You won’t be able to upgrade anything in that laptop that would be worthwhile.
getting a new one with a better GPU Is probably your only realistic option.
Chimpee
Hi Folks,
16GB RAM
500GB in C drive
2TB in D drive
Cole
I think it will help if you gives us a budget, but if it is for productivity, a laptop Ryzen 4800H will helped a lot as you get 8 cores 16 threads and pair it with a AMD 5500M or Nvidia 1660Ti or RTX 2060, you will have a decent gaming laptop. You will probably spend around $1,100 to $1,200.
smithco
Thanks! Budget is not a real concern...I spent over $4K for this laptop, and frankly it still does not render as quickly as I'd like, so I am definitely open to any recommendations!
defaultluser
The 5500 and 1660 Ti are the exact same performance as a 1070.
If you want better GPU performance in your laptop, maybe it's time you give desktop a try? Then it's pretty easy to buy a beefy system, and then upgrade the GPU.
Chimpee
If that is the case, a laptop with 2070 Super non max q or 2080 non max q will help a lot in any GPU rendering. Though it is only available for Intel laptops for the time being, I haven't seen any laptop paired with a AMD CPU yet. I have not seen any laptops available with a 2080 Super non max q variant. Though defaultuser does have a point, if you don't need to lug a laptop for work, 4k goes a lot farther if you are building a desktop.
deruberhanyok
Do they throttle CAD performance on GeForce cards still, in which case you may want something with a mobile Quadra instead? Or is that not an issue anymore?
Chimpee
From GamerNexus testing AutoCAD, a GTX 1080Ti performs exactly the same as a Quadro P6000, both have the same CUDA core counts, so it is not much of an issue anymore.
Mchart
If it has to be a laptop, can you at least settle on an eGPU for when you need the extra GPU? Both razer and alienware offer solutions.
smithco
That would be ideal, but my work takes me to 5 states, so I have to travel with this thing. LOVE the weight in my ba
I was not aware of an external unit. 75% of the time I am at the home office, so that could work well for me, and just work without it when on the road. Suggestions as to model? And is it accessed through a Thunderbolt cable or the like?
Mchart
https://www.dell.com/en-us/shop/alienware-graphics-amplifier/apd/452-bcfe/gaming
https://www.razer.com/gaming-laptops/razer-core-x
The razer core x will work on pretty much any thunderbolt 3 egpu supporting laptop. The Alienware only works on Alienware and I believe uses a proprietary dell connector only on the supporting Alienware laptops.
The Alienware combo is cheaper, even more so if you get typical Dell discounts of 15%-20%, however, it is more limiting given being locked down to Alienware and it doesn't support quite as large GPU's.
The Razer one is better all around though. Far better support and works with both PC & Mac, and supports larger GPU's. That being said, i'd likely buy a Razer laptop anyways just to ensure you never have issues with drivers/software support that almost always exist with things like this.
There are other options on the market, but I wouldn't recommend them given that they are kind of doing their own thing and you can't be sure you'll have rock solid support.
smithco
Thank you!
defaultluser
Thank you!
You can also buy a Thunderbolt 3 external dock, but then you need to make sure you buy a laptop with a a full x4 dedicated slot for Thunderbolt expansion bus (you're going to need the bandwidth to feed a fast card).
https://3dinsider.com/thunderbolt-3-external-gpus/
But the upside Thunderbolt 3 is it's a universal standard, so you should be able to continue to upgrade cards/reuse the enclosure.
Do you think you could cart around an expansion box? You could always leave it in your car, and only break nit out when you need to do ma demanding render.
