sabrewolf732
- Dec 6, 2004
Hello Just set this up, whitewater, chevette radiator, and a via aqua 1300. Cost me about $60 for everything. The temps are pretty awesome imo, but look higher than other peoples Im running a lidless venice at 2.65GHz with 1.62-1.63v and Im loading at around 42-44c. For coolant it's 50/50 antifreeze premixed coolant from kmart, said to not add water so I just added it as is. Fan is a 40cfm 120mm fan mounted directly to rad. Are my temps ok? Also, wondering if I should add pure water into the mix, and if a shroud will help lower the temps. K, thanks, bye. Right now temps seem on par with good air?
