Nice!
I picked up a SanDisk 4gb Extreme III card for like $30 shipped a couple weeks ago..=0
WTF! Where? I picked up the 2gb A-Data Turbo (266x) for $22 from the egg but 4gb for a few dollars more? Seriously
Nice!
it will be in a hall with half of the lighting coming from outside
July is sort of close. I would wait to see if Nikon will release a D90 with new sensor. Maybe it wouldn't ship in time but it might knock down the price of D80 some.
If it doesn't come out, I'd get the D80 + Tamron 17-50.
Don't really see myself doing a lot of long distance shooting so probably get an all-around lens something like that Sigma 18-200 OS or something similar.
Meh... if his brother already has a 10D then why not stick with Canon, that way they can share lenses for the time being. That Tamron 17-50mm f/2.8 is a nice lens, I just picked up the Nifty and I am starting to look as to what to save up for next. Don't really see myself doing a lot of long distance shooting so probably get an all-around lens something like that Sigma 18-200 OS or something similar. Don't have a lot of money to spend on it right now so probably going to be looking for something used under $400.
Suggestions?
Simply because I believe at this moment Nikon is a better system in dynamic situations. Canon at this moment is lacking a working auto ISO feature and the flash system isn't as good. These two features are paramount in getting the picture you want easily and quickly. There's less fuss with the camera and you concentrate more with the scene. I use both so I have experience.
I'm with you - got no use for auto-ISO. My camera doesn't even have auto modes: PSAM. I use A 90% of the time
I think Auto ISO would be a step in the right direction for Canon.
I think the full manual controls should still be there, but it is time for the cpu's and programming to be a bit smarter.
I also propose a simple DOF calculator and display system on the camera.
There used to be a mode called DEP on Canon cameras. It's like defunct now unfortunately. http://luminous-landscape.com/tutorials/dep.shtml
A-DEP from the description in the link I gave is not the same as DEP and seems useless. There aren't enough focal points to choose from and they are not edge to edge.
I was simply talking about being able to read the focus distance on the lcd, and also having two other numbers to each side of it. Maybe by convention, the one on the left would be the limit of the nearest object in focus, and the number on the right of the focus distance would be the farthest object still in focus.
Note that that link you gave compares A-DEP to DEP on the first rebel (300D), D30, D60 and 10D. I agree on those older cameras it is not as nice, but on the newer ones that is not so much the case. It is much better on the newer cameras like the 30D and 40D because there are more focus points and the focusing system is much improved.
I read it changed a bit over time but the fact is A still stands for Auto. If you have time to mess with it, that's perfectly fine. What do you do? rotate your camera, zoom in and out to wait for the right focal points to light up? It's guess work. On DEP you choose the closest, furthest points you want with the central (most sensitive sensor), recompose then shoot.
Thats a very good combo.
I hope you are not saying $1300 for that combo though, it can be had for much less even brand new:
Xti ($535)
http://www.bhphotovideo.com/bnh/controller/home?O=cart&A=details&Q=&sku=457506&is=REG
Tamron 17-50 ($420)
http://www.bhphotovideo.com/bnh/controller/home?O=cart&A=details&Q=&sku=423714&is=REG
= 954.90 + ~$16 S&H = $971 all said and done!
I guess, but the idea is to get everything in focus, so you are not selecting portions of the frame to get into focus anyhow.
It also works pretty darn well on the 30D I have, so dont knock it if you have not used it.
You can make up for it as well by knowing about hyperfocal distances and using manual mode and such, A-DEP is just good in a pinch.
Fair enough, I did oversimplify that. Also I stated as well that I like manual better, so we are in agreement on that
xti, D40(x), and xt are still good choices though on a budget, I have seen work from those that rivals even the best digital cameras. The tools are perfectly capable, the shooter makes more of a difference. Glass also adds a lot more than the small features between the bodies IMO. The XTI is also pretty much the rival to the D80, so if you can say a D80 is fine, so should the XTI be fine. In fact the XTI's IQ is superior to the D80 in a few tests I have seen (including those from www.dpreview.com).
As I said, I am not a Canon fanboy, or Nikon fanboy. I like to see the table evenly, and thus you have to be fair to both sides.
