I've been waiting to build out a new system to replace my Synology 1812+.
Here's what I have planned.
Case: Lian-Li PC-Q26B
MB; X10SDV-4C+-TLN4F
PS: Seasonic SSR-450RM
MEM: Kingston 16GB ECC
STOR: LSI SAS 9210-8i
Boot: 32GB USB Flash
OS: ESXi + Passthrough contrller to Xpenology or just straight Xpenology.. Otherwise RockNAS or Ubuntu?!
I don't consider ZFS as an option since you can't grow your array in a nice way, but I really want the benefits that ZFS provides.. Also, I've grown fond of the amazing Synology interface. So, the plan would be as follows:
Use Synology Hybrid RAID and Btrfs to have a very dynamic and easily expansible Array...
8 drives dedicated to the Raid 6 Hybrid array... Different size drives (like drobo)
2 drives mirrored for the OS, downloads and so the other drives can sleep more often to save power.
Performance isn't a huge concern.. mainly need a safe place to store things, with the ability to flexibly grow and swap out drives one at a time as they get cheaper or I need more space.
Any thoughts? This is a bit of a sanity check.. it all seems like it should work, but I'm not aware of anyone else going this route as of yet. Thanks
