Zurginator
- Nov 16, 2009
He's just had issues and been out of town. I gotta cut it myself or find another cutter though. :/
Aditional question - did anyone try the Coolink Corator DS cooler in this case (even better if on AM2/AM3 system).
Nevermind, Corator DS can't be rotated by 90° on AM2/AM3 and in standard position it won't fit (it will overhang the motherboard by about 1cm).
Considering I already had 2 480s and 12 gigs of DDR3, why not?wait what? u put a 980X in here...gosh damn....lol
One can also that Red and Black don't go good with Blue and Black.One can also argue that you could of gone for the Rampage III Gene...
Ok, so in short this would be the setup, except the few things i already own most of the stuff can be changed.
My main concern is stil the CPU cooler (size) and PSU (non-modular). Would you recommend me to change CPU cooler to something else (NH-U12P SE2 - 52.6, Megahalems - 52.3 + 12.65 for AM3 kit, HR-01+ - 46.15, Ninja 2 - 39.3) ?
- Da Box 100 BlackHeart (of course) (160+38,3)
- MSI 880GMA-E45 (95) - center of AM3 socket is 63.66mm from the right side and 115.55mm from back panel according to my measurements based on product picture and official motherboard size.
- AMD Athlon II X3 440 (3GHz) (73)- this should be enough for the graphics card
- Zotac GTS250 Eco + Accelerero L2 Pro - 19cm long, 2,5-3 slots wide, in PCI-E x16 slot of motherboard, taking all slots but the PCI-E x1 above it. (i already own this card)
- Coolink Corator DS (40) - 140x121x155m, can be mounted only in the way towards the back of the case, thus the cooler will overhand the motherboard on right side by 140/2 = 70 - 63.66 = 6.34mm. Do i need to remove the side fan for this ?
- Corsair XMS3 CMX4GX3M2A1600C9 (95) or OCZ OCZ3BE1600C8LV4GK (105) - both 2x2GB, DDR3-1600 kits. I will probably use them only at DDR3-1333, so there shouldn't be any problems.
- Intel X25-M G2 80GB ( (i already own this SSD)
- Seasonic S12II-330 Bronze PSU (i already own this PSU, but can be replaced)
- Enermax T.B. Silence fans
Hi everybody,
Working on these front audio ports.
I'm not sure where the problem is at this point... It's a big headache!
Non modular PSU may be a problem, but as far as fitting the heat sink, look at this shot of my Cogage Arrow:
You can see that I was able to fit my 4/8 pin auxilliary power connector beside the motherboard, but you also have additional room beyond that. I've already fit an HR01+ in this case:
Me, I'd definitely get Da Box rather than Mini P180. For both features and size, in fact. But if the shape is not suited to your wants/needs, I guess that is indeed an obstacle. But for hauling around, the Mini P180 really isn''t a good pick. Even my SG03 (about same volume as Da Box, but tower-shaped) is larger than I'd prefer for that, which is why I might go to ITX later this year if I can afford it after medical bills I'm forced to deal with soon.
That said, I'd take SG03 over a Mini P180 without hesitation, too
Fair enough. I only NEED to move my computer once every six weeks or so, but if I COULD move it, who knows what the possibilities are. I have only ever build a full tower so I am intimidated by this. I suppose my priorities are cooling my components properly and simplicity of the build/maintenance. Pretty much the opposite of SFF cases. I am going to read this whole thread over the next few days and decide, but Da Box looks pretty awesome right now. Any glaring issues with it I should be aware of?
Thanks again for your advice.
That ITX build sounds awesome. I am still reading through this thread to get the best picture of the box in my head before I make a decision. I definitely like the product and the company going out like this to get suggestions and actually utilize them is a big plus for me.
The Mini P180 does fit well with my desk arrangement and I have heard its nearly inaudible, but its hard to carry and I feel like it wouldn't handle cooling 2 video cards as well. I may need to sleep on it. The mini would be free because Dell has it and my Dad offered me anything sub 200 from Dell.com for my birthday.
I think that says a lot about my intrigue in this case to withstand that offer
Yeah I bought the two GTX 460's due to their relatively smalls stature (8") and they are more energy efficient and cool.
I am a little confused where people are putting their hdds in this thing. I have a 160gb raptor and a 750gb WD that I would like to put in my system.
Also, for someone like me who wants to use a i7 920 D0, and may want a light overclock in the future (but probably wont), what hsf would you recommend? I want to keep everything cool but I don't need to overkill it, and I feel like if it were smaller it would make working on the system easier overall. I don't know how some of you guys plug things into your mobo around those monsters.
I am a little sad that I can't get a windowed version soon as I see they are out of stock. Any ETA on those?
Good news: 480 got here.
Bad news: I hooked it up to the waterloop without testing.... it's DOA.
Speaking of fans, I see that Da Box comes with several fans listed, does this mean fan mounts or are the actual fans included with the case?
Close to pulling the trigger on this one! Though I want to get the case soonish so I can build it before classes start in August, so a windowed version is probably out of the question for me. Any LED suggestions as well?
Massive Overkill,
Do you have your H50 mounted outside the case? All the reviews I have read that mount it inside have the fan blowing over the radiator into the case. The new H70 looks promising as well and it is only a little pricier.
The arrow looks nice but I want room to work in my case and I think that would make it nearly impossible. I don't plan on overclocking too much, maybe 3.33 or 3.5ish.
Do fans come with this case or do I have to buy them separately?
Do you have a picture of this set up? I can't imagine it unless you reversed the rad/fan. I am leaning towards the h50 right now only because I have a 40 dollar best buy gift card, but I have also heard people having noisy versions. I'd rather not have to drill/clip/puncture any part of the case if possible as I am still new to this building computers business. I do like the challenge of the small case though.
Ah thank you for the pictures. So your system is pressurized for force air through the radiator w/o a fan, and the dual fans pull it out of the case? I may buy a 2nd fan for a push/pull set up. I can't decide what is better, using cooler air from outside the case to cool of the radiator, at the cost of higher in-system temps, or using hotter air in the case to cool of the radiator.
