Hey, Chopped liver!
My MOM is better than your MOM.
.....seriously....stick in the radiator pump cpu and gpu blocks in already
On the down side, I can't mount my radiators.well on the bright side....u have good ventilation?
I can't order DaBox in the EU shop.. Whenever I try to add it to cart it says "parse error", and after that it keeps telling me "Hack attempt: "no default carrier""
please see your sig for the reason.
HTTP Error 404. this is what happens when I drunk post...which is why I usually stay in GenMay when under the influence.
Is anyone else having problems getting the front panel audio to work? I get faint static plugging headphones into the pink port, and absolutely nothing from the green port. I really don't know how to determine if the issue is related to the motherboard (Gigabyte P55M-UD4) or the front panel header. The USB ports work just fine...
One question though: wanted to move the front black cutout on the DVD cover but the double sided tape may be the most adhesive thing I have ever used. Has anyone had any luck on ungluing it and putting it back? Any help on this subject is appreciated.
thanks for your help sabregen, i will try that tomorrow. i saw the same thing when i googled the removal of double sided tape, but didn't know how comfortable I felt about heating up the case. looks like it shouldn't be a big deal.hair dryer or heat gun + screwdriver or razor blade to lift it at one edge. once you have an edge up, getting it with your fingers and pulling is easy.
