New SFF gamers case: presentation and advices
Discussion in 'Small Form Factor Systems' started by mattinv, Sep 29, 2009.
  1. lillimon04
    lillimon04 2[H]4U
    3,762
    Oct 24, 2006
    I like LG01, haha Think silverstone would get mad? Haha Thank you! And I also like Deception, its pretty funny and it explains the concept.
  2. 3DChipset
    3DChipset Gawd
    670
    Sep 3, 2007
    This case doesn't really stand out too much. I've always wanted to design a microATX case or Mini-ATX case but obviously don't have the skills to build one.
    Want to stand out? How about putting the CD ROM and the HD on the bottom while the removable motherboard tray is above the two? This would free up the whole top section for ventilating. Hell with SSD's starting to come into play, power and heat wouldn't matter if these are mounted underneath the motherboard.
    Just a thought. If you are going to design a case, you might as well think outside the box and take a route no company will. The "me too" is sticking to me on this case. It's not different enough. just my two cents.
  3. sleepeeg3
    sleepeeg3 [H]ardness Supreme
    4,857
    Mar 4, 2004
    Aesthetically I like the front and overall design. I also really like that you are using all aluminum and slightly thicker guage. My thin 1.0mm aluminum case isn't really holding together well.
    That's a creative position for the PSU, but you block most of the front airflow and waste the space above the cards. It looks like only half of one 92mm fan is open.
    As is, I think the biggest risk in your case is making the exterior asymmetrical and at the very least you should consider making the other side windowed. I would also either put mesh over the top blowhole, put in a second or get rid of it entirely.
    If you widened one or both sides to allow for dual 120mm fans, that would also make a world of difference in cooling. Biggest flaw in cases in general is that they lack significant active intakes and that will be a moderate problem on this case design.
    Here are three ideas I had for an ideal SFF cases. These have the ability to add watercooling, ATX motherboards or both without wasting much space:
    #2
    Dimensions: 389 x 305 x 229
    Setup: Dual 120mm rad in the front / 120 mm fan on each side
    #1
    Dimensions: 389 x 300 x 253 OR 350-336 x 300 x 291
    Features:
    -ATX Mounting (sideways)
    -Support for Dual 120mm Radiators or large size heatsinks
    -Support for oversize power supplies
    Setup: 2 x 120mm intake fans (top left side)
    #3
    305 x 254 x 254 (243 width only leaves 9mm for cables)
    Setup: ATX mounting sideways, PSU sideways, dual 120mm rad on the right, CDROMs moved left, hard drives bottom right, bottom right rear 120mm fan
    Anyway, good luck with your case. It's good to see some still trying to innovate out there.
  4. craigbru
    craigbru [H]ard|Gawd
    1,451
    Jan 25, 2006
    Nice looking little box. I'll be watching...
  5. Groats
    Groats n00b
    38
    Dec 26, 2008
    How about the "Lan Gear Pandora XS" for the m-atx and "Lan Gear Pandora XXS" for the m-itx?
    Can't wait to see your itx design!
  6. jamesman32
    jamesman32 Limp Gawd
    421
    Jan 11, 2009
    Perhaps "Lan Gear MaxPak", because you're packing a lot of stuff into a small space.
  7. MassiveOverkill
    MassiveOverkill [H]ard|Gawd
    1,748
    Jul 8, 2005
    Before the recession hit, I used to travel with my Micro Fly just about monthly. I'm currently using a Sugo Bag to carry it around in. If someone (hint, hint) made a bag that would fit the majority of your SFF cases like the Sugo/Micro Fly's or smaller, and it had a collapsable handle and wheels like your typical luggage set, I'd buy it in a heartbeat.
    It would be nice to have a hard shell and would have to fit in the overhead compartment of a commercial jetliner or underneath the seat of a commuter plane. Inside would have to be thickly padded just in case you were forced to check it. A seperate accompanying monitor carrying case OR even an integrated LCD screen built into the top of the case (as an option) would be nice as well.
    I am in a position that proposes demo-solutions for our salesforce. The demo consists of running 3-4 VMwares (more as we integrate more modalities). Previously our salesforce had to have full tower Dell servers shipped to the demo-site and the whole demo scheduled. I have been able to condense the VMwares down a bit and using a dual core laptop with 4 gigs of RAM and an SSD, they are now able to demo the solution on their laptops and do a demo on-the-fly. The demo barely runs as it maxes all the resources out.
    I'm not the one who chose the model of laptop, I was given the task of making it work on one. They are balking at getting quadcore laptops and 12 gigs of RAM with 3 hard drive bays because they are so used to the limited capacities of the overpriced, "high-end" Dells they order. The long story-short of this is that mATX rigs are the solution. They have to haul around 22" monitors anyways.
    We're doing our budget next year and I have been pushing mATX rigs. The cost savings over a Dell tower server is immense. The only problem I have with my Micro Fly is that the material is thin and it has to be modded to fit the components I have put into it (minor mods, but if you have to build 30 of them, it becomes a PITA). That, and I get a good workout hauling it around in my Sugo bag. I've tried the folding wheeled carriers, but that's one more thing to carry around.
    Don't make your bag proprietary to your case.
  8. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    Thank you for this very instructive feedback.
    The bag is not proprietary to our case. We want you to be able to use it with the most common SFF case (there is a system of removable hard protective foam that can be added or removed to adjust for each case). It will just have a designer touch to it, and it will be designed more like a fashionable bag, rather than a "I'm going to the gym" type bag. I work mostly on the design of the case and I haven't seen the latest design yet, but I can tell you, it's going to be a good looking SFF case carrier. We are shooting for a December release for the bag. I'll post pictures online as soon as we get the first prototype made.
  9. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    The "front" airflow is composed of 2 x 92 mm fans (aspiration- not blocked) + 1 x 60 mm fans. For the exhaust, we have 2 x 120mm fans @ 68 SCFM each, 25 dBA. I believe from the first test this is going to work quite well but we will post some results when we get the second prototype done.
    We discussed about using the ATX motherboard for a while but we opted for a Micro ATX because of size restriction. Maybe we'll have an ATX version if the demand is there.;)
    Also, make sure you check revision N2, it is quite different from the first prototype.
  10. xanvincent
    xanvincent [H]Lite
    84
    Aug 6, 2009
    Look forward to seeing that new prototype!
    As far as names go, I agree with keeping it simple and easily memorable.
    Something like The Lan Gear Cage (to go along with caging the beast inside, as you mentioned). "Box" just sounds too generic and doesn't paint a good picture of the ideals you're trying to get across.
  11. lillimon04
    lillimon04 2[H]4U
    3,762
    Oct 24, 2006
    Haha box is very generic, but Da Boxx is just sweet, explains that its da shit. Ya digg?
  12. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    A few suggestions for the names:
    #1 Evolution 800C
    #2 Precision M200
    #3 Original 400
    #4 Quality VP10
    #5 TinyPower 400D
    #6 BlackPower 100
    Anything that sounds good to you?
  13. Yuritau
    Yuritau n00b
    59
    Sep 9, 2009
    Your ideas seem like they might be decent ones.. but, no offense intended, if you're talking about ATX mobos, you're not talking about SFF anymore.
  14. jamesman32
    421
    Jan 11, 2009
    I don't really like any of those personally, only because the numbers are nonsensical, and the names don't exactly describe what the product might be. As corny as it may be, a LanBox needs a ricey name to describe what it is. Or, if you wanted to do a combo of something sophisticated and descriptive, you could try something like "Lan Gear LanPerfect 100"
  15. lillimon04
    lillimon04 2[H]4U
    3,762
    Oct 24, 2006
    What about Lan Gear Precision, sense this is exactly what we want in a matx case, its precise! Anyone?
  16. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    These names were just suggestions and I have no idea what to pick for this case yet. Later, I will make a summary of all the suggested names. At the end, you guys are going to decide, not me.
    Black Power referred to the fact it was going to be all black inside and out (we are thinking to have the interior all black since the price difference is not excessive).
    The number after each name was just an exemple.
    It can be called LG01 Precision, LG perfection, LG Lanperfect, .... or anything else you can come up at this point.:D
    Please, keep on suggesting!
  17. kencheeto
    kencheeto 2[H]4U
    2,851
    Apr 17, 2008
    What about
    Inception
    Synergy
    Micro
    and you can add any appropriate suffix (XS or MATX or whatever)
  18. lillimon04
    lillimon04 2[H]4U
    3,762
    Oct 24, 2006
    I like LG01 Precision, thats sick. And if you make the black interior on some of them than there could be a BP after the name for the all black one, Haha I can see some people getting mad for writing out black power. Haha.
    LG01 Precision BP
    LG BP01 Precision.
    Idk something tight!
  19. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    Since I'm white, I can probably afford to call it that:p. A dedication to our president?:D
  20. tvih
    tvih Gawd
    566
    Aug 16, 2009
    It's certainly looking interesting feature-wise, many features I've often wondered about why they are missing on currently available products. I've had some rough plans and ideas about a case of my own for that reason, but given I don't have the means or engineering skills to ever actually produce one, it never went beyond that phase :p
    That said, regarding the style of your case. It's nice, definitely reminds me of some of the Sugo cases in outward appearance. One thing that bothers me is the power (and I assume reset?) buttons, they seem distracting. But that's just my opinion of course :)
  21. lillimon04
    lillimon04 2[H]4U
    3,762
    Oct 24, 2006
    Been looking at the front, not pretty anymore, I like the old one except for the grill. My idea would be to make the dvd drive stealth with a regular 5.25 cover, and with the usb and extra ports under it, then with the power buttons in the same place but different buttons, these ones, http://www.frozencpu.com/products/8...using_-_Ring_Illumination.html?tl=g44c341s875. Green would be a plus! And then for the grill, do like this, http://www.lian-li.com/v2/en/product/product06.php?pr_index=336&cl_index=1&sc_index=25&ss_index=61 or http://www.lian-li.com/v2/en/product/product06.php?pr_index=147&cl_index=1&sc_index=25&ss_index=63 with that line around the holes all the way around the grill, ya know? And that light behind it makes it look sick!!
  22. tvih
    tvih Gawd
    566
    Aug 16, 2009
    Oh, forgot to comment on the drive cover. I've never been a fan of those. My SG03 build now uses a 5.25" Scythe Kama Panel 2 with an attached slim optical drive. Serves a couple of functions. Seems like a waste to have a full-sized 5.25" bay and then "block" it from special uses, if you know what I mean :)
  23. lillimon04
    lillimon04 2[H]4U
    3,762
    Oct 24, 2006
  24. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    Registered.
    It will be designed with a bezel so that you can use the 5.25" bay any way you'd like.;)
  25. lillimon04
    lillimon04 2[H]4U
    3,762
    Oct 24, 2006
    Did you like anything that I said? I think it would look hella sick if it was like that.
  26. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    Lilli, I appreciate every feedback.
    To make it quick. We will offer a version with a slightly modified front, where the 5.25" bay is open (too many different wants and needs we cannot fulfill in time). But as of today, we are in the process of making the prototype and we cannot make any more modifications. Fortunately, this is something that can be added (/changed) to the finalized case.
    We are planning to be done by the middle of next week with prototyping.
  27. lillimon04
    lillimon04 2[H]4U
    3,762
    Oct 24, 2006
    Sounds sweet! can wait!
  28. Polyp
    Polyp n00b
    15
    Oct 6, 2009
    I've been a long time lurker but I created an account just to give a name suggestion =)
    What about "BlackBox" ? Like the flight recorders!
    And if you're really looking for version numbers, just give something simple like:
    BlackBox 1
    Having words like power/precision/evolution may sound more childish than you want
    Great job with the case so far, I'd definitely pick one up for my next SFF build
  29. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    Thank you all. I'm glad to hear you are liking the case. Wait to touch the 2mm thick brushed aluminum finish. It's a beauty!:D
    I will recapitulate all the name that have been suggested. Maybe we should have a vote?
    Also, regarding the paint color. Painting the interior all black is nice but quite spendy. Would you be interested in an anodized aluminum, yellow or red maybe (yellow is fairly common so not expensive. I don't know about red)???
    Please, let me go if any of these suggestions sound good.
  30. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    In random order, the list of all the suggested names so far:
    BlackBox 1
    LG01 Precision BP
    LG BP01 Precision.
    Inception
    Synergy
    Micro
    Lan Gear Precision
    Evolution 800C
    Precision M200
    Original 400
    Quality VP10
    TinyPower 400D
    BlackPower 100
    The Lan Gear Cage
    Da Boxx
    Da Box
    Lan Gear MaxPak
    Lan Gear Pandora XS
    Lan Gear Lanbox
    Lan Gear SFF Case or Cube
    Massive Overkill Mobile
    Lan Gear Ultimatum
    Anything that you like more than the other?
  31. Ruiner
    Ruiner 2[H]4U
    3,058
    Aug 22, 2000
    My top 3, in order.
  32. tvih
    tvih Gawd
    566
    Aug 16, 2009
    Black interior would certainly be nice, but of course it's tricky if it's expensive for some reason. The biggest annoyance (looks-wise) with the SG06B is the gray interior, and even in the SG06B the gray is visible in the side panel seams for example, and of course in the back.
    What comes to the names, a good name is hard to come by. Trying to be too "cool" with the name usually ends up in a negative mental image, yet many don't like too plain names either. Lose-lose situation :D
  33. jamemail
    jamemail n00b
    27
    Feb 14, 2007
    You can count me in or at least one of these cases when they come out.
    I like:
    Lan Gear MaxPak
    Lan Gear Pandora XS
  34. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    To solve the problem of the interior paint color and the impact on the cost of the case, we are going to offer 2 versions (maybe 3). This will let people choose which one they want and not cost us any extra.
  35. DTN107
    DTN107 [H]ardness Supreme
    4,781
    Jun 30, 2008
    Damn I like this case. But I am almost done modding my Lian Li V351.
    Looks like I gotta donate it to the family as an excuse to pick up this case!
  36. lillimon04
    lillimon04 2[H]4U
    3,762
    Oct 24, 2006
    LG01 Precision
    Lan Gear Lanbox
    Lan Gear Da Box(or Boxx)
    Lan Gear Micro
    Lan Gear BlackBox (Would be weird if it came in different colors)
    Lan Gear Precision M200( Dont know where the M200 came from, its cool! But maybe M100 since its the first version?)
  37. sleepeeg3
    4,857
    Mar 4, 2004
    Nice, I would probably be interested in that, too. :cool:
    Since you free up one of the 5 1/4" bays, if you were to tilt the PSU sideways and raise it up, you could fit 3 unrestricted 80mm fans in the front. Then move the hard drives back to where MO was talking about. There is an idea...
    The N2 revisions should help airflow. I would drop the 60mm fan because they don't do much for airflow and tend to be noisy. I would not waste money on painting the interior black.
    I don't want to get off topic, but consensus on "what is a SFF" basically was that it had to be a certain size. Probably should take a look at whatever you are running, because almost every SFF case could fit one with modding. It's all about design. ATX in an X-Qpack has been done before. ;)
  38. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    The bad news first.
    Because of the cost of having the case all black inside, we are looking at $25-$30 difference:( between the case all black and the one without this treatment. So you guys will be able to decide. This price difference will also include a window.
    The good news is that we might be able to drop the price of the cheaper model.
    Also, we might be able to post some picture of the latest prototypes in 2 weeks from now.
    Any more questions?
    Any more names suggestions?
  39. kencheeto
    kencheeto 2[H]4U
    2,851
    Apr 17, 2008
    I think
    Lan Gear Precision
    Lan Gear Micro
    would probably be good bets. I would hate for Lan Gear to use really bland flashy names like BlackStorm XXS LG1001 or something. The case is classy- the name should reflect this.
  40. Yuritau
    Yuritau n00b
    59
    Sep 9, 2009
    My top three.
    BlackBox (drop the #, imho)
    Da Box
