New SFF gamers case: presentation and advices
Discussion in 'Small Form Factor Systems' started by mattinv, Sep 29, 2009.
  1. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    Hi everybody,
    On another notes. I know we talked a lot about DA BOX lately. But I wanted to show the bag that's coming your way and see what you think. We used some pretty high quality material. Designed in Italy by an Italian designer. Here are the first pictures of the prototype.
    [​IMG]
    [​IMG]
    [​IMG]
    The baby bag for your accessories that goes inside.
    [​IMG]
    The inside of the baby bag.
    [​IMG]
    This is our first prototype. So there are a few defects. But you get the general idea.
    I don't want you to think I have been sleeping lately or anything (I mean, in between postings).:D
  2. rubberwheels
    rubberwheels n00b
    24
    Dec 29, 2009
    The bag looks awesome, love the color scheme.
  3. Yoy0YO
    Yoy0YO Limp Gawd
    312
    Aug 20, 2009
    I really like the bag! You should include straps to hold onto a keyboard outside of the bag. Some keyboards are ridiculously long
  4. arnemetis
    arnemetis 2[H]4U
    2,687
    Aug 2, 2004
    Still brainstorming on my water cooling idea and would love it if someone could give me these two clearances:
    [​IMG]
    Original image from FengPangzi, hope you don't mind! If someone could just quickly give me these two dimensions I would really appreciate it.
    The bag looks pretty good, I agree on the inclusion of some way to carry a keyboard, as they are usually longer than our case's 14.6" :) (My saitek eclipse II is 19.6", for example)
  5. MJZ
    MJZ [H]ard|Gawd
    1,200
    Oct 25, 2009
    If I had a ruler, I'd tell you. I'd estimate 12.5" long, a little less than 8 1/2" inches wide. Using an 8.5 x 11 piece of paper as reference.
  6. Skott
    Skott 2[H]4U
    3,972
    Aug 12, 2006
    That bag is pretty nice looking. I agree with the others you should try to incorporate a way to carry a keyboard with it if possible.
  7. Blazestorm
    Blazestorm [H]ardness Supreme
    6,940
    Jan 17, 2007
    I'm debating between a m-ATX build with this case and a m-ITX build with a PC-Q08... either way... I think I'l get that bag :D
    Just curious what the baby bag is for... mouse?
    I think one compartment for the case itself, well protected, and other compartments mainly for cables and whatnot would be fine... maybe bigger pockets that could hold Switches would be nice for those who bring 8port switches/routers to LAN's. But looking at it now I think it's fine as is. One bag for my system, one bag full of the cables and switches, spare mice and headsets etc.
  8. msny
    msny 2[H]4U
    2,190
    Sep 5, 2001
    The bag looks great.
    One suggestion for long keyboard carrying.
    Make a thin bag accessory thats over 20 inches long
    by a few inches wide. It would have a long zipper on top
    and either velcro or clipson the bottom. You may want to
    put light padding in the inside of it all around.
    When the inside case itself is zipped up at the top, the keyboard bag would
    lay on top of it between the straps used for carrying then
    secured to it.
    I realize it would overhang on two sides, so you could then
    wrap the entire case in another larger zipped outside
    case overlap. The straps for carrying would be on the
    inside case and fish though to the top and outside. If
    the outside case overlap is strong enough, you could
    pur some zipped pockets on either end for more storage.
    Since I dont know the weight or stress points involved
    someone would have to figure that into the overall load.
    Heres a primitive visual.
    ---- ---- carrying straps
    -------------------------------------------------------------------------------------------- outside case overlap
    surrounds the entire setup, with possible zipped pockets inside
    ---------------------------------------------- keyboard padded bag zipped
    longways
    keyboard latches to the inside case with velcro or clips
    --------------------------------------------------- inside padded case as shown in
    picture above
    Take this drawing and turn it upside down, for what it would look like.
    Wider at the top, smaller at the bottom.
    http://www.abcteach.com/basicshapes/images/trapez9.gif
  9. Steeeeve
    Steeeeve 2[H]4U
    2,596
    Jul 26, 2005
    Very nice color and design looks good. My suggestion is to make sure it can fit more than just "Da Box". For example the SilverStone SUGO Bag can hold mini-itx cases and matx cases...everyone I've tested.
  10. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    I think you'll be able to fit most micro ATX cases, but I'll check to make sure it is at least SUGO and Q pack compatible. I don't think it will be a problem to fit mini ITX cases.
    Our next mini ITX case will fit in it like a charm. Actually, you'll be able to fit 2.
    The baby bag is for whatever you'd like to have protected in it. One of the use for it was for high end expensive mouse that you don't want to have floating unprotected.:)
    Here is a picture to show you how it opens. It's actually designed so that you can just slide it inside very easily. The entire top parts goes up and leave the bottom compartment wide open.
    [​IMG] >> [​IMG]
  11. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    Good morning,
    The custom power cords are being produced as we speak. They will all be tested and rated for 2000W. Hopefully, that will solve any future issues with them, especially because we are using them in our new upcoming mini ITX case.
    Mini ITX project: Announcement / debate
    I haven't talked much about it because we have been working on resolving the technical issues with DA BOX. But it is moving along.
    In order to offer the best possible product, we have decided to change a bit our development approach. We noticed we had quite a few suggestions to improve DA BOX, and we'd like to have all of these suggestions taken into account for our next mini ITX project.
    This is why we decided to create a BETA test of the product. This is what I'd like to discuss with you and see what you think.
    Here is how we are thinking to make it work:
    We would select 6 candidates that will receive the case, starting with the first/second prototype. They will pre-purchase the case with a deep discount, and will own the final product.
    After they receive each prototype, they will make a list of suggestions and improvements. And then ship back the case so that they can receive the new improved ones. They will keep testing it until they get the final product. Shipping will be all paid for.
    I don't know if it has been done before. But it should be interesting.
    You'll end up with a very nice mini ITX case for cheap.
  12. Groats
    Groats n00b
    38
    Dec 26, 2008
    Hey mattinv, any chance of a peek at the mini ITX case design?
  13. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    Hi Groats,
    We will start posting some pictures when we get the first prototype done. Not before because we have big plans for it and we'd like to keep it under the radar for a while. But we are ready to start prototyping.
    The only thing I can tell is that if you are looking for the ultimate mini ITX case, this is it. And I have no doubt you will love the design.
  14. Hofy
    Hofy 2[H]4U
    2,475
    Jun 3, 2004
    Matt, could you shed some more details on the mini ITX prototype beta?
    I may be interested as I have a couple of mITX motherboards and several hard drives (3.5" and 2.5") along with both standard optical and slim drives.
  15. arnemetis
    arnemetis 2[H]4U
    2,687
    Aug 2, 2004
    Matt, it seems my question has been lost, maybe you can answer it for me? Just need those two dimensions above, in post #1045. Also, are the overall dimensions listed on the website still accurate? Thanks.
    *edit* MJZ, saw your post but would appreciate something a bit more exact. Less than 8.5" seems way off, since the case is 11.4" wide. I cant believe those two support pieces are 1.5" each, to be honest visually from various pics I was estimating a bit more than 10", which is critical because I need 9.8" clear. But thanks anyway! (and if you are right then I have to scrap my project :()
  16. Silentbob343
    Silentbob343 [H]ard|Gawd
    1,753
    Aug 2, 2004
    width appears to be 10.03125 and length is 12.78125. these were taken from the edge of the lip, so you have a bit more room than that.
  17. arnemetis
    arnemetis 2[H]4U
    2,687
    Aug 2, 2004
    Silentbob343 - THANK YOU! That is precisely what I needed. And I'd much rather have a 'worst case' edge of lip measurement as you have provided, as it still ensures I have room to do what I wanted. Looks like you got yourself some nice digital calipers ehh? :p
  18. MJZ
    MJZ [H]ard|Gawd
    1,200
    Oct 25, 2009
    Oops, yes what was I thinking. I meant to say the width is little less than 11.5" depending on how you measured. :) Around 10" sounds right if you are measuring from inside edges.
  19. FengPangzi
    FengPangzi Limp Gawd
    321
    Oct 31, 2009
  20. arnemetis
    arnemetis 2[H]4U
    2,687
    Aug 2, 2004
    So much awesomeness. Thanks FengPangzi!
  21. Silentbob343
    1,753
    Aug 2, 2004
    Matt,
    Interested in taking part in this beta as I will be building a new HTPC this month with a Zotac MITX board.
  22. HaX
    HaX [H]ard|Gawd
    1,912
    Dec 17, 2005
    mini itx project, score!
  23. MassiveOverkill
    MassiveOverkill [H]ard|Gawd
    1,748
    Jul 8, 2005
    Mattinev, I don't know if that's going to fit in the overhead compartment of a plane. It may if you slide it in sideways, but with heavy tower heatsinks, I'm squeamish about transporting my rig while on its side, especially during landings. I do like the color scheme. The other thing is having a wheeled assembbly for when you have to travel 1/2 a mile from one end of the terminal to the other.
  24. bheath3
    bheath3 n00b
    35
    Dec 16, 2009
    Matt,
    I am not a pro builder by any means but I am willing to help out if you need people. I will be building a HTPC within a few months. Let me know more details if you need help.
  25. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    Sorry about that. Must have missed it.
    From the picture you sent, the exact dimensions are:
    Blue line: 11.2"
    Red line 13.8"
    I hope this helps.
  26. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    Hi Everybody,
    Here is the specification of the first prototype.
    Dimensions: 11.85 (long) x 9.28" (wide) x 5.97" (tall) (same volume as SG05)
    100% aluminum
    Power supply: compatible ATX
    Motherboard: compatible mini ITX
    1 slim DVD drive bay
    Fans: 2 x 120mm + 2 x 80mm (excellent cooling)
    Compatible with video card as long as 11.6" (PCB) (so a bit more for the entire card lengh). It looks like it might be compatible with some 5970 in the future.
    Compatible with fairly tall heatsinks: 5.5" (must be tested for clearance)
    1 x 3.5" hard drive bay
    2 x 2.5" hard drive bay
    (1 hard drive for storage, 2 SSD for speed)
    Smooth lines design. Glossy paint + 2 shades. Custom colors.:)
    It is purely gamer oriented but I will personally use one as HTPC because of its good look.:D
  27. Kil4Thril
    Kil4Thril 2[H]4U
    2,974
    Sep 21, 2003
    Matt, I would be very interested in testing the ITX box. I have a mobo, drives, opticals, PSUs, and vid cards to try.
  28. HaX
    HaX [H]ard|Gawd
    1,912
    Dec 17, 2005
    Awesome, can't wait!
  29. rubberwheels
    rubberwheels n00b
    24
    Dec 29, 2009
    Here's my attempt at cable management. i know it sucks. if anyone has suggestions please tell. I tried to route all the wires underneath the optical drive because there's space between that and the PSU. I used the 3 pin fan attachments because using model would require another wire attached to the PSU. I tried to flip the hard drive so that the connectors would be facing the 92mm fan cause i mounted mine in the front.
    Matt: When should we expect the new front bezel, etc...?
    [​IMG]
  30. Blazestorm
    6,940
    Jan 17, 2007
    I'd be interested in the beta testing for the Mini-ITX case, I've been doing a lot of Mini-itx stuff and am probably going to move my next system into one.
    I was looking at the PC-Q08 from LianLi... bit bigger but packs a lot of stuff too.
  31. Oruf
    Oruf [H]Lite
    93
    May 29, 2008
    Thinking about buying one of these. However I am confused as to the difference between the original and the "blackheart". Is the window the only difference?
  32. Blazestorm
    6,940
    Jan 17, 2007
    I believe the interior is the raw aluminum vs. painted black. in the classic.
  33. FengPangzi
    321
    Oct 31, 2009
  34. sabregen
    sabregen [H]ard as it Gets
    18,888
    Jun 6, 2005
    size it for a G15 and you'll be fine. Bonus point is you can also design a bag for my G25, my G13, and my G35's. yeah, i know.... /gear whore
  35. Yoy0YO
    Yoy0YO Limp Gawd
    312
    Aug 20, 2009
    That Racing wheel would make it quite difficult to pack into. It'd be a challenge, maybe just stow it separate from your case
    also:
    Line the interior or your bag with lead. This would make it easier to travel through customs.
  36. sabregen
    18,888
    Jun 6, 2005
    I line my bags with Plutonium. It's the only way that I can generate the 1.21 Gigawatts that I need for my daily commute to 1985.
  37. psypher5
    psypher5 [H]Lite
    70
    Aug 8, 2005
    Can't wait to hopefully get one of these in the UK. Have been told end of feb though (they are looking for a retail seller in the uk) :(
    And they wont be able to do a red interior :( lol
  38. EtronicTek
    EtronicTek n00b
    21
    Oct 25, 2003
    USPS finally delivered my case. Overall it looks good other than the faceplate issue. Have yet to check the power cord since I still don't have all my parts.
    Also looking forward to the mITX case. I have a SG05 now as my main but will likely hand it down and use either the blackheart or this as my main.
  39. mattinv
    mattinv Limp Gawd
    473
    Dec 4, 2008
    Hi everybody,
    We are still waiting to receive a sample of the new faceplate to confirm production. But it will hopefully happen pretty soon.
    I will also keep you posted on the progress being made on the Mini ITX case and the new power cords.
  40. EtronicTek
    EtronicTek n00b
    21
    Oct 25, 2003
    thanks for the update matt. keep up the great work!
