Lateralus
More [H]uman than Human
- Aug 7, 2004
I think I may have found a possible (this is only a theory) culprit for what could be causing the lag.
I tried two things. I noticed that smarthub was turning on automatically when the TV came on. So I shut that off. Two... people are reporting that the lag gets worse and worse over time with the panel being on. So I had a thought. These tv's are basically really weak computers with a monitor built in. The have processors and ram, and run a rudimentary "OS" in a sense. So, I thought about old PCs and how they would bog down if you don't restart them. So I gave it a try, I tured off instant on (samsungs way of not making the software reboot, but going into a hibernation) and turned off auto start on smart hub...
My ghosting and lag seem to be better! I know this should not affect ghosting in theory, but it seems to as well as input lag by a great bit.
I know this seems random, it could possibly be a number of things since I made so many changes. But I just thought it may be worth a shot. FYI I have it set up as DVI PC and use a true dvi to hdmi cable as well. 444 not game mode uhd enabled 4k
I never set up SmartHub on my 7500; maybe that is why I haven't noticed any of these lag issues that you guys have been talking about. I just assumed that I was less sensitive to input lag than others. My 6700 and 7500 have always felt good to me. I can detect a little more lag in PC mode, but it's still very tolerable. I primarily use Game mode though, since it looks virtually identical to PC mode when not viewing red text, and Samsung reduced the lag through recent firmware updates.
So this issue doesn't affect me, but if SmartHub does contribute to the lag some users are experiencing then that sucks because doesn't that mean if you disable SmartHub that you won't be able to use apps like Netflix, etc.? Which is fine if you're using this ONLY as a monitor, but anyone who uses it for a TV or streaming device will probably want the extra functionality enabled. And to further complicate things, for those of you wanting to stay on the stock firmware, how would you use the apps on the TV that require internet connectivity, yet ensure that the TV doesn't update itself (since disabling Auto-Update doesn't seem to actually disable it)?
I'm just glad that I'm happy with the new firmware. I can't imagine discovering that the stock firmware was vastly superior in terms of lag, and then going through the huge hassle of exchanging my updated TV with another one from Crutchfield, and then trying to keep it on the stock firmware, and then discovering 6 months down the road that I goofed up and connected it to the internet for some reason and it updated. I feel for you guys who are only happy with the stock firmware and trying to stay on it indefinitely. It seems like you sacrifice a lot in order to do so.
What input are you using for DVI PC? Are you using #2 like coolhand? I can't remember which one Nitemare is using. I still don't understand if there is any difference between input 1 and 2 when using Device Type = DVI PC.
