New Receiver Integra DTR-7.9
Discussion in 'Home Theater PCs & Equipment' started by B239, Sep 5, 2008.
  1. B239
    B239 n00b
    51
    Aug 20, 2008
    Reason for Editing
  2. StorageJoe
    StorageJoe Limp Gawd
    460
    Jun 14, 2005
  3. w1retap
    w1retap [H]ardForum Junkie
    11,967
    Jul 17, 2006
    Looks very nice. But I really dislike how they spread the speaker outputs along the entire bottom of the back of the unit.
  4. Zefram0911
    Zefram0911 [H]ard|Gawd
    1,157
    Apr 19, 2002
  5. Ripskin
    Ripskin 2[H]4U
    2,226
    Jan 15, 2004
    I second that, looks great but I like to lable my speaker wire's and zip tie them to one side instead of have them spread out with all the rest.
    Otherwise nice
  6. CrimandEvil
    CrimandEvil Dick with a heart of gold
    19,671
    Oct 22, 2003
    So... Other then viral marketing whats the point of this thread? It's a nice receiver, does it perform well though?
  7. B239
    B239 n00b
    51
    Aug 20, 2008
    Reason for Editing
  8. B239
    B239 n00b
    51
    Aug 20, 2008
    Reason for Editing
  9. wildfire99
    wildfire99 Gawd
    720
    Mar 6, 2007
    For $1.3k they could have at least used the "good" binding posts.
  10. Riddlinkidstoner
    Riddlinkidstoner [H]ardness Supreme
    4,102
    Aug 12, 2006
    jesus what cheap binding posts. my yamaha v663 has better ones at a quarter of the price.
    (i use an external amp so nyeh :p)
  11. w1retap
    11,967
    Jul 17, 2006
    I hope you spent at least $20,000 on speakers.
  12. StorageJoe
    460
    Jun 14, 2005
    Ha, i thought the same when I looked at their receivers. That note aside, I do really like Integra products. They lack polish in some aspects, but overall are a pretty solid product for the money. You really should have sprung for one of the units with the HQV Reon for processing. My DTC-9.8 has it and it is vastly supurior to the Farauja DCDi in the lower end - mid tier Integra and Denons.
  13. th3 godfather
    th3 godfather Gawd
    564
    Feb 25, 2004
    5 hdmi in is a nice feature however. better than the 0 my pioneer vsx-1015tx has :(
  14. B239
    B239 n00b
    51
    Aug 20, 2008
    Reason for Editing
  15. figgie
    figgie [H]ardness Supreme
    7,820
    Feb 11, 2002
    Say what?
    $1300?
    Umm the specs look identical to the $599 Pioneer VSX-1018AH-k.
    On that list you put. Crestron? Home automation and just starting to branch out into the power amplifier department. But that means direct competion with Crown, QSC, JBL etc.
    Mark Levison. After Mark levison took off. Nowhere near the same as before.
    btw quit the snobbishness here. Integra is made by Onkyo.
  16. IDversusEGO
    IDversusEGO [H]ardness Supreme
    5,015
    Oct 30, 2003
    The same company is responsible for Dodge and Mercedes, but I'll take a s600 over a neon any day.
  17. StorageJoe
    460
    Jun 14, 2005
    Not anymore. That is a terrible analogy. Ford and Mercury would be more accurate. The Integra stuff is exactly the same as the Onkyo except for cosmetic differences and custom installer features (RS232 integration and such).
  18. IDversusEGO
    5,015
    Oct 30, 2003
    ok, so my info was dated as of last year, but it cant be terrible if you knew what I meant ;) . And I dont know the details of these receivers, my point was that a parent company doesnt mean that all products are the same. ford has jaguar, mercury, volvo, and aston martin. GM has
    Cadillac, chevy, hummer, pontiac, and saturn (among others). there are large differences in some of their products and little to no difference in others. If the poster would have said "this is identical to onkyo model xxx I would have understood.
  19. B239
    B239 n00b
    51
    Aug 20, 2008
    Reason for Editing
  20. figgie
    7,820
    Feb 11, 2002
    let see how much difference there are.
    130watts @ 8 Ohms x 7 (Check, BOTH pio and Integra)
    Integra , THX Ultra 2, Pioneer, ThX Select.
    HDMI I/O. Check (3 for Pio, 5 For Integra)
    HDMI upscaling of all video to HDMI output (Check, 720p, 1080i, 1080p)
    Latest Codec Support (Check both, Dolby TrueHD, DTS-HD-MA)
    Room Calibration Option (Check both, Audessy on Integra, Propriatary Speaker Cal on Pioneer).
    On-Screen display (Check for both)
    RS232 (Integra only)
    So there you go.
    RS232 and 2 more HDMI inputs. Yep I can see that they are NO WHERE NEAR THE SAME...... Look at the INSURMOUNTABLE POWER DIFFERENCE. One is archaic compared to the other (I am being facetious). :eek:
    Again, quit the audiophile "snobbery" as it serves no purpose. You bought it because you like it or whatever. That is all dandy. But better? based on numbers. NOPE. Now subjectively BETTER to you. That is a different story.
    And as you said, THINK (in your case, RESEARCH) before you speak. All specs are available online and Audio video Science forum has them too (which I belong to).
  21. kent
    kent 2[H]4U
    2,526
    Apr 8, 2001
    I like my $50 HTIB
    Just kidding.
  22. eon
    eon 2[H]4U
    2,218
    Oct 11, 2003
    noob question but why does a audio receiver need video input? shouldnt that go directly to your tv?
  23. figgie
    7,820
    Feb 11, 2002
    It could
    but what if you have
    A PS3
    Xbox360
    and A Wii
    Cable/Satellite
    Would you not want to have a "video" switcher to switch between them all? :) It would be easier than hooking and unhooking cables and you do it the first time and that is it ;)
  24. kent
    kent 2[H]4U
    2,526
    Apr 8, 2001
    Not only that, but it's one less remote, unless you own a Harmony, like me.
  25. StorageJoe
    460
    Jun 14, 2005
    And less cabling. If you're hanging a tv on the wall for example it's much easier to just string one HDMI cable to a receiver than hook all video sources direct to TV. Also, some do video processing. My Integra 9.8 has the HQV Reon chip in it and upscales everything to 1080P.
  26. criccio
    criccio Fully Equipped
    12,436
    Mar 26, 2008
    Much quicker way to answer your question. Its an Audio/Video Receiver, not just an audio receiver.
  27. pre1014
    pre1014 Limp Gawd
    428
    Apr 23, 2004
    Hmmm, I've liked my yamaha much more than every sony i've ever listened to. I guess my subjective opinion is incorrect. I suppose i'll go hide under my desk and cry now.
    Actually, I'm happy i own a yamaha because then i don't have to be an "audiophile." Those guys are snobs. :p
    I suppose my nuvo whole house audio system is crap too since i didn't spend 30K on it.
