New Price Drop - 8TB WD External Easystore USB3 (8TB WD Red Inside)
Discussion in '[H]ot|DEALS' started by klank, Apr 23, 2017.
  1. Edgar
    Edgar 2[H]4U
    2,329
    Jul 24, 2005
  2. Eulogy
    Eulogy 2[H]4U
    2,155
    Nov 9, 2005
    "That code has expired"
    Whew... I would've bought had it worked!
  3. SomeGuy133
    SomeGuy133 2[H]4U
    3,478
    Apr 12, 2015
    newegg had yesterday 2x6TB HGST for 330 o_O i wanted them but too broke TT
    talk2troy likes this.
  4. westrock2000
    westrock2000 [H]ardForum Junkie
    9,207
    Jun 3, 2005
    Transferred my 10 disk ZFS array over to 2 of these drives. Coincidentally, both the esata cards disappeared on my Mac, so I ended up having to connect the ZFS drives thought USB2 ports. Took 48 hours to copy 12TB over at 50MB/s. The Reds had no issues. I did take them out of the enclosures and used the rubber screw mounts they come with and put them under the bare drive to hold them up off the table. They didn't get hot, just warm.
  5. talk2troy
    talk2troy Don't Hurt My Feelings
    6,268
    Jun 10, 2004
    I do big transfers sometimes via external USB 3 docks like these:
    Amazon.com: ICY DOCK EZ-Dock MB981U3-1S 2.5”/3.5” SATA HDD/SSD USB 3.0 Docking Station
    Sabrent USB 3.0 to SATA Dual Bay External HD Docking Station Built-in Fan 2.5 or 3.5in HDD, SSD HD Duplicator/Cloner Function [8TB Support] (EC-HDFN)
    I also run a 12" fan (like this) or a 20" box fan (like this) over them from about 4-5' away just for peace of mind.
    I also do a "touch test" and the difference w/ out a fan (hot) vs. with a fan (almost warm) is AMAZING.
    Gives me some peace of mind anyway...
  6. Lunas
    Lunas [H]ardForum Junkie
    9,616
    Jul 22, 2001
    deal from best buy is dead for now amazon still has some for 199 but amazon...
  7. Lunas
    9,616
    Jul 22, 2001
    Got another efax from amazon
  8. Eulogy
    Eulogy 2[H]4U
    2,155
    Nov 9, 2005
    Once again, these are back down to $179 on BestBuy.
    brentsg and maclem8223 like this.
  9. d.v.
    d.v. [H]Lite
    95
    Jun 15, 2011
    thanks for pointing it out, been waiting for best buy to drop the price!
  10. Design1stcode2nd
    Design1stcode2nd Limp Gawd
    411
    Aug 17, 2016
    Thinking of getting one of these for an HTPC I am building I was looking at a 6TB Toshiba for a similar price. Anyone know how prevalent the white label drives are? I'd hate to shuck one just to have to take it back. I've got a BB gift card I've been meaning to use which sweetens the deal.
  11. Lunas
    9,616
    Jul 22, 2001
    Nothing wrong with the white label versions.
    The wd80emaz is a fine drive too still a hgst nas grade helioseal drive
    I ordered 2 this last month both were wd80efax red though.
    If you are going to go into the store you can make sure to pick a Thailand country of origin one... Otherwise spin the wheel the only one of the 4 drives you dont really want was used in early models the wd80ezzx. Or the china one wd80efzx. I have been assured that ALL wd drives are made at the thailand factory though...
  12. Design1stcode2nd
    411
    Aug 17, 2016
    I would be going in store, how do you determine country of origin, is it listed on the packaging? Also I thought the white label units would not work if shucked (unless power was modified)?
  13. Lunas
    9,616
    Jul 22, 2001
    No they work they have an added feature that if you provide them 3.3v they enter a reset state. If you remove the orange wire or use a 4 pin to sata adaptor they work fine... Or if your backplane/pc/psu supports the feature it will also work fine.
    And yes in the barcode on the outside of the box it will say made in china or thailand...
  14. Design1stcode2nd
    411
    Aug 17, 2016
    Thanks!
    So even if I got a white label I could use this and it would work fine? https://www.amazon.com/Molex-Power-SATA-Female-Adapter/dp/B000YJMB5Y
  15. DriveEuro
    DriveEuro 2[H]4U
    2,611
    Jun 23, 2004
    Design1stcode2nd likes this.
  16. Lunas
    9,616
    Jul 22, 2001
    Yep. On your sata connector there are 3 voltages that are provided. 3.3v ground 5v ground and 12v each is 3 pins on the connector you can remove the orange 3.3v and be fine with 99.9% of drives. It is nothing to remove the connector from the plug then if you dont want it permanent you can put some electrical tape over it then tie the 3.3 out of way.
  17. westrock2000
    9,207
    Jun 3, 2005
    Do ATX PSU's have a 3.3v in the SATA? I've never seen anything but the red/yellow. As far as I know the 3.3 is only in the 24pin. I know that SATA standard allows for it bit I have never seen it in the enthusiast market.
  18. Lunas
    9,616
    Jul 22, 2001
    my evga 400 watt i just bought had a orange on the power connectors... it is the sata 3.3 spec if your equipment is compliant with that then it should work no mods needed... Prior the 3.3v rail was present on the sata connectors full time and with the exception of very few drive nothing used it...
  19. note235
    note235 [H]ardness Supreme
    4,932
    May 23, 2005
    what's the white label version?
  20. Design1stcode2nd
    411
    Aug 17, 2016
    As an option (not for those who need big storage) Newwgg has 10% of on some drives the Toshiba X300 5TB ends up being $127.77.
  21. Verge
    Verge [H]ardness Supreme
    5,194
    May 27, 2001
    Pretty sure one of mine failed this morning.... The only drawback of shucking, no warranty.
  22. arnemetis
    arnemetis [H]ard|Gawd
    1,340
    Aug 2, 2004
    I've read stories of some on reddit just returning the bare drives and getting them replaced, but really you could just pop it back in a case as long as you didn't break the tabs?
  23. Lunas
    9,616
    Jul 22, 2001
    the white label that is currently showing up is the wd80emaz and some have pulled back the label to reveal it is a hgst ultrastar helium drive with a controller that has Power disable turned on...
    which pull and manufacture date?
    wd80ezzx
    wd80efzx
    wd80efax
    wd80emaz
    And i kept the shells of mine and mine barely got scratched when i shucked them...
  24. rasesh
    rasesh n00bie
    51
    Nov 20, 2015
    Hey guys, you really know your stuff about these drives aswell as some other's on this thread.
    Ill be honest and say I'm illiterate about all this but it's a deal I really need.
    I'm wondering if you can just use a couple minutes of your time to try and see if you can find this deal for me in Canada on Bestbuy.ca or Amazon.ca?
    I don't know which one I would have to get or which 1 is the best deal to get the 8Tb Red as you guys have mentioned.
    Thanks!
  25. Lunas
    9,616
    Jul 22, 2001
    dawsonkm likes this.
  26. rasesh
    rasesh n00bie
    51
    Nov 20, 2015
    What about this 1?:
    https://www.amazon.ca/Western-Digit...1508186575&sr=1-1&keywords=WDBBGB0080HBK-NESN
    If I bought from amazon.com it transfers to me as $167 USD = $212 Canadian which for us camped to the above is great as that saves us a bit.
    Only problem is if you look at amazon.com at the moment why does it say that you can only buy it "USED" ?
    Take a look: https://www.amazon.com/Book-Desktop...1508186433&sr=8-1&keywords=WDBBGB0080HBK-NESN
  27. Lunas
    9,616
    Jul 22, 2001
    that one doesn't have a red in it... it is a wd80ezzx or a purple or green label it seems harder to shuck too ill look in my 4tb when i get home see if i can see the label in the vent though... and that says used because there are no new ones being sold on amazon so other people like you or me are selling them on amazon the question is did the seller use it format it then box it back up or did they shuck it and toss a 8tb seagate they got out of a datacenter or a white label no name drive they got for 1/3 of the price the WD drive cost them. Or did they shuck it and put anything else inside... you wont know till you get it and by then it will be too late...
  28. rasesh
    rasesh n00bie
    51
    Nov 20, 2015
    I see, on the first page people asked if it was the same as the one I linked on amazon.ca above & "WhoBeDaPlaya" said they are the same just with different model number's.
    Not too sure but Canada doesn't hold the "Easystore" WD drives anywhere it seems.
    Ya'll need to help us Canadian out too eh?
  29. Lunas
    9,616
    Jul 22, 2001
    nope from a search the my books have slower white label drives in them supposed to be equal to a wd blue or green the board for usb looks the same though. Kinda curious about putting a not 8tb in the enclosure of the easy store now... the my books require removal of pins 7 and 8 on the bios chip of the usb board...
  30. masakisho
    masakisho n00bie
    3
    Sep 26, 2017
  31. Lunas
    9,616
    Jul 22, 2001
    Just a cursory glance already shucked drives on ebay yields https://www.ebay.com/sch/i.html?_fr...1.A0.H0.Xwd80efax.TRS0&_nkw=wd80efax&_sacat=0
    There is only 1 source for wd80efax drives and that is the shucking of these easystores as the efax in 8tb models is a custom sku for the best buy only easystores it is most likely a firmware limited wd100efax that failed qc with all 7 platters active but passed with 2 turned off
    A few of those ebay drives are at the 200 price point. The wd80efzx is the china model drive and has slightly higher failure rate so dont go for them...
  32. El_Capitan
    El_Capitan Limp Gawd
    235
    Nov 11, 2012
    Btw, I got 4 of them, all WHITES. One is defective. I'll be returning it to the store and getting another. If it's a RED that I get, I'm willing to trade for a WHITE. I'm putting all four of them in a RAID 10 configuration is why.
  33. Lunas
    9,616
    Jul 22, 2001
    which white drive the bb easy store or the mybook?
    wd80emaz or wd80ezzx
  34. El_Capitan
    235
    Nov 11, 2012
    Got my replacement at my local BB store, it matched what I had, the wd80emaz. Not too bad for a 4 Disk RAID 10.
    [​IMG]
  35. Lunas
    9,616
    Jul 22, 2001
    those are hgst he8 enterprise drives if you dont have a psu or backplane compatible with sata 3.3 spec it will not spin up to fix you need to remove the 3.3v line on the power connector.
    i know they are working now but the above is for if you encounter the issue later...
  36. El_Capitan
    235
    Nov 11, 2012
    Yeah, they have molex to SATA connectors. My PSU has a +3.3V rail, but it wouldn't work. I had to use the +5V rail and the adapters in order for them to show up.
  37. Lunas
    9,616
    Jul 22, 2001
    In the sata power connector all that needs to be done is the wire on the end with the L shape key cut that last wire leaving the 4 others if using colored ones the orange wire is the 3.3v wire that needs to be removed the sata power spec v 3.3 has it that the 3.3v line is used to control some things and has it work a bit different. Where as prior to that it is a steady on which those drives percieve as signal to be in a reset state. So with a non compliant psu or back plane it wont spin up unless the 3.3v line is cut or not passed via the adaptor method.
  38. Edgar
    Edgar 2[H]4U
    2,329
    Jul 24, 2005
    ITS JUST THAT EASY!! lol
    Docjon likes this.
