Due to circumstances, may need to sell my PC and build a new one. My last build was in late 2008 (i7 920) with a few upgrades to components later, so I'm a bit out of touch with the latest developments. As this wasn't planned, would appreciate any advice.
- Light work, light gaming, the occational movie as it'll be connected to a 5.1 surround sound system. Needs to be very quiet.
- Would prefer to save money, but willing to spend more to ensure a quiet energy efficient PC. Don't mind spending a bit more to get a powerful PC, but nothing that's overkill. And as I'll be putting my own time into the the build, I can pay a bit extra, within reason, for asthetic reasons.
UK.
Probably need the most help on the CPU and motherboard.
- CPU. Probably one of the Sandy Bridge CPU's, perhaps one of the new Sandy Bridge E's. (EDIT) Thinking of the i5 2500k as it looks like the Sandy Bridge E's are 135TDP. The i5 2500k is not much of an upgrade on my 3 year old i7, but at least it's slightly more energy efficient.
- Motherboard that has the latest USB and SATA formats. (EDIT) Thinking of the Zotac Z68 ITX. Can switch to mini-ATX if that's considered to be a bad idea.
- GPU (SLI/Xfire is out of the question). Was hoping for something better than my 5870, either in terms of energy efficiency/noise or power. Preferably both. (EDIT) Had a look at what's around out there and can't see anything that's much of an upgrade. Might even consider a 6870 as it's energy efficient while being 'almost' the same performance wise. But if anything new coming out soon, I can wait
- SSD. Decent 120GB compatible with the latest SATA version. Was considering either the OCZ Vertex 3 or the much cheaper Corsair Force Series (not GT)
- PSU. Looking at this high end fanless Seasonic 460w.
- Case. If I go ITX, then probaly this Lian Li Q11 ITX case simply because it looks nice. Wish it could handle 3 hard drives (+SSD), but I'll settle for two if necessary. If I have to get something bigger, looking at this Silverstone FT03.
- Memory. No idea but whatever works.
Windows 7, keyboard, mouse, 1900x1200 monitor, sound system, hard drives.
6) Will you be overclocking?
Will be undervolting. May overclock if the CPU speed is under 3.0Ghz.
1900x1200 monitor
If all the parts are available now, will build it next weekend. If not, will build over the next 2 months. Willing to use IGP if need to wait on the GPU side.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
- Latest SATA and USB. Preferably highly energy efficient.
Win7 64bit.
UK.
1900x1200 monitor
Win7 64bit.
