Hello
So I have the new Asus Strix Extreme mobo with a skylake 6700k, the pins on the motherboard are bent, and they managed to make a scratch on two of the copper electricity receivers (on the cpu, not the core in the middle).
I am thinking the cpu might still work as long as the copper receivers still make contact with a working mobo. The mobo pins are bent and I need to replace it, so I am wondering if the CPU actualy is damaged and let's say I get a new mobo, can the damaged cpu damage the new mobo ?
If there is enough resistance on the small copper dots (receivers) where each of the cpu socket pins on the mobo connects to the cpu, then it should in theory work.
Also, what is the odds the cpu is still working ? Will I suffer performance loss even there is less resistance on two of the elctricity receivers ?
