Where did you get that 5.25" bay blank that matches the main fans grills so well?
I picked it up here at frozen cpu.
Good price! I have a similar setup but air... 1st bought A70 but too tall so bought Noctua NH-U9B SE2.i just picked up a 354v off the egg for $87 shipped. anyhow, ill be running a gene-z 1v z68 and 2500k. can anyone confirm working coolers for this case and board?
Also ordered one from newegg for $87. Moving my OpenIndiana system into it. Going to need all drive bays for 2tb disks.
just couldn't pass that deal up myself
great little cooler,but i have an hx750 psu and i'm really worried about clearance. then after alittle more reading i might not go h60 either to due longer vcards. theres some great rigs in this thread,but i wish people took better pictures of ram and heatink clearance.
i would love to see more pics with hseries coolers mounted some where other than the front.
Modular for sure. How big a psu will depend on what you plan to do with it. For single GPU and overclocking a 600w should be plenty but you can get by with less. I have a 850w modular unit in mine in case I ever wanted to go dual 6950s.
i haven't ordered a cooler yet, still going back and forth on the h60 and noctua ch12
Uploaded with ImageShack.us
Sneak peek of mine. I'll post better pics when my cpu comes in on tuesday.
looks good man. is that a thermaltake cooler? looks like a pretty thick rad.
im still on the fence with my cooling, but if it where me, i'd mount it in the front. i dont want to drill new holes in the rear for it, nor do i want to lose space in the front incase i go with a longer vcard. if you do decide to mount it up top plz post pictures. i was wondering about this myself. i'll more than likely go air cooling on mine.hey guys... just about to start my v354 build... going to be using a h50 that i had mounted in my SG05 (boy that was fun!) and i'm seeing some people mount it down the front in a push/pull config and some at the top rear... i'm wondering what will be the best config...
front mount push/pull worries me as technically you're blowing hot air onto the gpu, no?
i'm actually thinking mounting to the roof of the case might be the best move, thoughts?
Has anyone fitted a GTX 670 in this case? Im thinking it should fit just fine if I remove the lower hard drive chassis.
for tower coolers like the Noctua U9B-SE2, would you recommend doing a push pull front to back or would you go for the top exhaust?
can you guys give me any suggestion on where to buy a SSD drive? Please.
