Edit: May have found the answer in the Revision B version http://hardforum.com/showpost.php?p=1034657538&postcount=1194 It looks as if it doesn't obstruct the ram? Would you agree.
Orginal:
Anyone know if Corsair Dominator ram will fit underneath the Big Shuriken or Thermalright AXP-140 on the zotac 9300 board?
Also in the PC-Q11 case can a fan be fitted on top of the heatsink or is the PSU to close?
As it's old ram i'm trying to buy the heatsink around. How does the H50 stack up noise wise to either of those 2 air cooled ones? It's not much more cost wise.
I don't know about that motherboard, but on the H55N-USB3, I highly doubt Corsair Dominator ram will fit under a Big Shuriken or the AXP-140. I have both HSFs and Corsair XMS ram and both HSFs clear the ram by a little bit. Any more and it's not going to fit.
