...just want to share it here...
Couple of questions about your original design (before watercooling):
That fan mounted at the bottom, below the video card, was it used for air intake or exhaust?
Did it make difference to have it there. Did switching to watercoling dramatically improve your temperatures?
Thanks!
the fan mounted at the bottom is intake. and yes it helps cool my videocard.
there's a big drop in temps when i switch to watercooling.
Hi,
I'm building by PC-Q11 but need some advice on Motherboard and CPU Cooler for a I5 3550 because I don't want to order them and realize they are too big or ther is not enough space to fit them correctly.
I am looking for a good but realiable M/B and silent cooler (I don't need overclock) I am considering Asus P8H77-I for M/B and I heard good things about axp-140 or axp-100 coolers.
Asus P8H77 seems perfect but looking at pics socket seems near pci-e slot and may give problem with VGA card with big heatsink like AXP-140, anyone can confirm?
It also seems like all other H77/Z77 Asorck or Gigabyte have some socket near to PCI-E slot.
Asus P8Z77-I Deluxe is expensive and I don't need OC tweaks or wireless features but seems to be the only one with well centered cpu socket with enough space for axp-140.
In your experience can you let me know what big cooler and silent fan I can place and be sure it fit the P8H77-I or other board/cooler/fan configuration so I can order them?
Thanks!
Sorry I meant H77 not H67, price are pretty much the same so no reason to go with H67. Asrock Z77 is a very interesting Z77 board with good price, comparing to the very expensive Asus Z77 Deluxe.
As said no need to overclock but I'm looking for silence and peformance, if I find that Asrock has same good CPU/Case fan control like Asus I'll go with Asrock. Thanks!
I finally ordered most of my configruartion:
PC-Q11 Black
Asrock Z77E-ITX
I5-3470
Thermalright AXP-100
4GB Corsair Low profile
SSD Samsung 250 Gb
Any suggestion for a quiet GTX 660 Ti that fit the case?
Where did you find the case if you do not mind my asking?
Hi guys!
After reading the thread from start to finish, I think I've finally got a list of components ready to go for a build of my own.
Lian-Li PC-Q11 Black
Asrock Z77E-ITX
Intel Core i5 3570K
2x4GB Corsair Vengeance 1600 Low Profile
Bringing across the SSD/HDD, GTX460 (will upgrade later, funds permitting) and Corsair HX-520 PSU from my old box to keep costs down a little.
My big question is about cooling - I've got it stuck in my head that I want to try out a WC solution, looking at the Kuhler 620 or the H55/H60. However, I don't know that the radiator + fan is going to fit with that PSU (it's 150mm long and modular). I did find a photo of a guy that had fitted one in his Q11, but I can't really tell from the photo if there would be room: https://lh4.googleusercontent.com/-bcfcRMk4efA/TzTROlflLlI/AAAAAAAAB10/WShPaCL6gSw/s1024/IMG_20120208_194655.jpg
Failing that, I 'm going to just pick up an AXP-100 and run it fanless, relying on the case fan to inject some cool air, and the PSU fan to extract it. Will I get acceptable temps with this, or should I really be looking at putting a fan on top of it (particularly if and when I decide to do some OCing a bit further down the track)?
Finally, I'm not going to be using the top 5.25" bay for an optical drive, so I was looking at putting in a SilverStone hot-swap bay to put my 3.5" storage drive in, like this - http://www.pccasegear.com/index.php?main_page=product_info&products_id=18420
It's cheap enough to take a gamble on, and I figure it'll fit, but if anyone knows anything to the contrary, please let me know.
Heh, that's my pic of the HX520. You can MAAAYBE fit a H60 in there, but it's going to be tiiiiiight. I would try running a H90 since the front fan is a 140mm fan, and the rad is 27mm. Also, you might have to swap the stock fan for a slim 140mm. I think Aerocool makes a 20mm fan. Either way, it's going to be quite tight.
Do take pictures if you try though.
After looking at the specs, all the fan/rad combos seem to be 25mm for the fan and 27mm for the rad standard (including the H90). Is the recommendation of the H90 because the Koolance 120->140mm adapter would add more size (making it too thick), and having a 140mm fan/rad will just barely scrape in?
Looks nice, but I think I'd want something a tad smaller.
I don't thing the AXP-100 fanless would be a good idea with your cpu, maybe a AXP-140 would be barely enough but will still need a high rpm 140mm case to blow enough air. I think two lower rpm fans (one for AXP-100 and one for the case) gives you more benfits and acoustic perfomance than fanless heatsink with single higher rpm case fan.
Asrock give you a good control on fans, just set the cpu fan (can control PWM only) at lowest level with ASock Utility and won't be audible, you can adjust the case fan too (can control both PWM and standard 3 pin). You can then set temperature limit when fans will slowly ramp up only when needed. It will probably less expensive and easier to maintain then a liquid cooled system.
I am now looking for another place to mount SSD
