New Gaming rig for under $1000... thoughts?
Discussion in 'General Hardware' started by paleh0rse, Mar 29, 2013.
  1. Xinmosni
    Xinmosni [H]ard|Gawd
    1,974
    Mar 12, 2012
    The OP will spend even more money than he'll make back on gas (not to mention time) spent returning those things.
    The build he got is great. Not what I would've rolled with since I have different needs and budget, but given he stayed generally within his budget, got a CPU cooler (stock HSF sucks ass, even if he doesn't OC), is satisfied, AND didn't piss off his wife is all that matters in the end. This should last him a good 2 years before a great need to replace his GPUs, unlike a single 7870 or 7950.
  2. Climber
    Climber [H]ardness Supreme
    5,283
    Jul 27, 2007
    Good luck with your build!
  3. ssnyder28
    ssnyder28 2[H]4U
    3,596
    May 9, 2012
    *EDIT* SORRY I WAS A BIT OUT OF IT AND MISSED ALL THE POSTS ON SECOND AND THIRD PAGES… MY BAD.
    I like the current build you have but you should get a slightly cheaper psu and get a better single gpu. You should be able to get a high quality psu in the 600w range and then get nothing less than a 7950 or 670 gtx. If i were you i would also get either a reference model or similar of those two card types and down the road buy another closed loop wc unit and modify the card to use it so you can get a great stable oc.
    Also are you buying an aftermarket cpu cooler? You should consider getting a closed loop water cooler so you can oc that 3570k and keep it nice and cool. I'll suggest a zalman lq-310 (only closed loop system that ive purchased) as the performance is excellent for the price.
    Climber made a good suggestion as the 256gb m4 sounds like a great ssd for you, i personally dont think youll see a big enough real world difference between that and the 840 pro to warrant a high premium. I have several ssds (a 120gb sata III sandisk extreme, 2 120GB intel x-25, and a 250gb vertex 2) I dont see much difference in the speeds in real world applications they are all blazing fast, just make sure you get a 250GB or larger drive, you'll be happy you did.
    If you are patient you can likely get all the components you want and stay within your budget.
