No, I use 1.4v I think. Since it doesn't go to 1600 without OC you can lower it to 1.3 or lower probably since it will run at 1333Just got the board. I've got 1.35v Mushkin sticks, and I'm wondering if there's a way to get exactly 1.35v vdimm. What is the DDR3 Terminal Voltage? Is it a voltage adjustment to the vdimm??
Hi
I got my dfi Mi yesterday everything was working fine but then this morning it didn't want to start up. The leds are on but nothing is happening when i put the power on. I tried a clear cmos with the pins and by removing the battery for 5 minutes but still no response. I tried also the clear cmos with the small button on the back, when i press it i have half of a zero on the led display then goes back the blank.
I didn't do any overclocking on my own, just the automatic ABS, the mosfets seems fine (no burning or anything). I use an i5 750 and 2 sticks of DDR3 ripjaws.
Any idea, am i in for a return?
Anyone have this running with an i3-530? I've seen some pretty decent reviews of the 530. I'm going to run it in a Silverstone Sugo SG05-B with the Corsair H50 (after modding the backplate).
I know the overclocking on this board is extremely limited but can I at least hit 3.8? I'll be adding copper mosfets heatsinks for added help.
i had my i3 530 up to 170 fsb i think that is limit , also had to raise vcore just a little bit above stock . used a h50 cooling system. was stable for me in tests i did
now plagued with the dual channel memory problems again, really thinking corsair memory isnt compatable with this board. either that i have now had two boards fail me this way . and i tested with two different cpus so i know its not the cpu. memory i tested 12 gb of corsair here in another system and its fine with memtest in windows. but dfi wont post now with both banks used .
sigh
Jen
http://www.newegg.com/Product/Product.aspx?Item=N82E16820145260
I'm running that corsair 2x2 XMS3 ddr3 on my DFI right now, I haven't had any issues
You slot died? was your board OC'ed automlatically via ABS? same happenend to one of my boards. Since then I strictly set all OC/Voltage options by hand
I'm much less interested in power requirement as I am about physical restrictions. I'm curious if (with or without a little modding) a 5870 could be squeezed in there, since it's power connectors are oriented to the top instead of the end of the card. Been considering upgrading (or downgrading as it were) from my matx i7 system to something smaller for traveling to lan parties, but supporting at least a 5870 is a concern.
Yeah, a little...just don't overtighten. You don't need THAT much force on it.
Just got this board myself, got it all set up, noticed i can't go any higher than 150bclk with my i5 661. After this heavy disappointment i noticed i have the bios from 2009-12-31, i quickly grab the current latest bios 2010-04-20 seeing all the awesome features like actually supporting the i5 661 and proceed to install it. After that's done, still can't go past 150, what's up with this?
limitation set by dfi to prevent damage to motherboard . same with the i7 860 i have max it can overclock is 150 fsb and i dont have voltage control . one of the main reasons i bought this board was for voltage control to undervolt it.
Ah, but what puzzles me is even with the old bios i was locked to 150 fsb, and i could be wrong, but in clunks review of the board with the bios revision that limited the fsb he said the i5's would have a maximum of 170 fsb
Wouldn't it depend on which i5 you're talking about? Right now I've got my i5-750 at 160, with turbo boost. Works well, just need a proper case so I can see how hot the vrm's are going to get.
Jen
This seems to be a hard problem to figure out. DFI keeps denying a problem exists and only a few folks have it. Seems oddAny update on the USB-wifi issues? I'm really stuck choosing between the DFI board and the Zotac H55.
